Gen 1: 2004-2005 weird overheating issue - Kawasaki ZX-10R.net
post #1 of 12 Old 06-27-2012, 04:35 PM Thread Starter
I was cruising on the highway today goin around 70mph. I wasn't lookin at my gauges and swear I saw the rpms do its self check cycle as if I just turned the key on. I shrugged it off thinking I was seeing things. Then a few moments later I see my temperature shoot up. Like 180-190-210-230- Hi in a matter of seconds. I shut my engine off instantly worried that my coolant leaked or something. I check my coolant levels and its topped off completely. I check my oil and its perfect amount maybe a little more and blackish color like it should be. I was stumped. I left my bike sitting for awhile for the temp to go down to about 170. I turrn my bike on for 2 seconds, literally, and the temp shot up to around 215. Keep in mind every time the bike shot up in temp the fan did not turn on at all. I also notice my gauge cluster did not power on when I turned the key one time. In my experience, I've seen this as an electrical problem. Improper grounding or a fuse went out. Any and all insight would be nice.
adub is offline
post #2 of 12 Old 06-27-2012, 04:54 PM Thread Starter
Also the water pump is working the coolant was flowing when I rev'd the engine
adub is offline
post #3 of 12 Old 06-27-2012, 07:23 PM
TexasRider's Avatar
have you drained the coolant recently?
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #4 of 12 Old 06-27-2012, 07:31 PM
Does not drive into smoke
El Zilcho's Avatar
Water temperature sensor acting up?
El Zilcho is offline
post #5 of 12 Old 06-28-2012, 09:26 AM Thread Starter
Possibly this. I'm truly stumped. I went to work for a few hours come back and it works perfectly fine. No idea what happened here wish I had the solution. I should add that I hhave the gen2 gauge conversion on my bike so I don't see if there is any fi light on. Electrical gremlins :\
adub is offline
post #6 of 12 Old 06-28-2012, 09:30 AM
TexasRider's Avatar
Water temp sensor may or may not throw a code. Make sure you dont have any air pockets in the cooling system...hence the reason I asked if you changed the coolant recently. An air bubble in the system can make it look like the temps are all over the place, and give fast HI readings...
07 zx10r- stolen
post #7 of 12 Old 06-28-2012, 09:43 AM Thread Starter
Hmmm I did add some coolant this past weekend. When I was testing if coolant flowing I did see a couple of small bubbles come out. I thought flushed out all the air but I may have left some in I guess. Do you have a technique for getting all the air out? I could try that to see
adub is offline
post #8 of 12 Old 06-28-2012, 09:49 AM
TexasRider's Avatar
I just tap all the hoses while its running....some people squeeze and release them. I keep it on the side stand when I check...this puts the radiator opening at the highest point...so any trapped air pockets should flow up. Pouring in coolant slowly helps push out air naturally too.
07 zx10r- stolen
post #9 of 12 Old 07-06-2012, 10:01 PM Thread Starter
for those who cared i found out what was wrong. a wire to my gauge cluster came loose that was all.
adub is offline
post #10 of 12 Old 07-07-2012, 05:02 PM
tone.r's Avatar
for those who cared i found out what was wrong. A wire to my gauge cluster came loose that was all.
we all care, i was going to tell you to check your fan i had my fan hitting the spring to my exhaust and had my temp tripping
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
07 making weird noises and acting weird Z-Rider Performance and Tech 17 10-03-2013 09:15 PM
weird no start issue. sam_b03 The ZX-10R 7 05-07-2012 05:20 PM
Need Help 06 Overheating TX06'10r The ZX-10R 56 10-09-2009 02:32 PM
Overheating dardar Performance and Tech 27 09-27-2009 08:41 AM
Weird position light issue on an 04, seeking help OrangeShirtDude Performance and Tech 1 10-19-2008 09:30 PM
