Gen 3: 2008-2010 weird oil leak - Kawasaki ZX-10R.net
post #1 of 11 Old 05-03-2011, 08:02 PM Thread Starter
bama~guy's Avatar
weird oil leak
i recently went to the track, i came off the line too high and came down pretty hard, when i got to the end of the track i noticed a small oil leak, i didnt hit the oil plug bolt didnt even hit the tab in front of it, the leak is dropping off the backside of the pan slowly........anybody know what this might be...thank u for any help
bama~guy is offline
post #2 of 11 Old 05-03-2011, 08:08 PM
lyodbraun's Avatar
post some pics of the area in question??
lyodbraun is offline
post #3 of 11 Old 05-03-2011, 08:44 PM Thread Starter
bama~guy's Avatar
notice the plug is in the front its dripping where my finger is....sorry for the crappy pics
leaked this much in about 20 min after running a little bit
bama~guy is offline
post #4 of 11 Old 05-04-2011, 09:08 PM Thread Starter
bama~guy's Avatar
thinkin it might be the oil pan gasket......any opinions please
bama~guy is offline
post #5 of 11 Old 05-04-2011, 09:11 PM
Is it wet anywhere above it?? you can look at my thread I have a phantom oil leak as well Im trying to figure out. It ran down and off the oil pan but after looking its coming from up above and behind the sprocket cover but its not the Valve cover or head.
04-ZX-10r is offline
post #6 of 11 Old 05-04-2011, 09:27 PM
All show and all go 10r
JLG0987's Avatar
Take off the fairings and wash it the bike, do an inspection FIRST. I don't know if they still do it but but every bike I've crashed has leaked oil and ends up coming from the oil breather on top of the valve cover. It's normal and can leak for a while. I had a 89 gsxr 750 I crash and I didn't run it from when I crashed it and it was still dripping oil 6 months later. It just pooled up top butthe oil level was fine.
JLG0987 is offline
post #7 of 11 Old 05-04-2011, 09:42 PM
Look at the clutch cover those two circles are known for slipping off in an accident.Timing inspection caps are what they are called
Magmadragoon is offline
post #8 of 11 Old 05-05-2011, 08:39 PM Thread Starter
bama~guy's Avatar
not coming from the caps ive been down that road already lol it sucked guess im gonna have to take it apart to find it ugh
bama~guy is offline
post #9 of 11 Old 05-05-2011, 11:03 PM
mrbzx7's Avatar
I still have the factory header but I cracked my pan three time, leaks where you describe. Mine cracks on the thin or flat part next to the sump, my exhaust hit the ground and goes up into pan. The pic is my second go around and I added some reinforcement.
mrbzx7 is offline
post #10 of 11 Old 05-06-2011, 12:17 AM
BlkCasper's Avatar
had same problem on mine. Hair line crack above mid pipe area where it goes under oil pan. Took forever to find. Remove mid pipe, run bike till its warmed up. Shut off, you'll be able to see where its leaking from. Temp Fix on mine by cleaning area and using jb weld. Pan can be welded probally from inside to seal, but a new one is olny abot 120.00 -150.00 from ronayers.com. good luck.
BlkCasper is offline
Need Help Guys. Weird leak. anaxagoras1986 Performance and Tech 21 09-03-2010 12:08 PM
I know you will think this is weird... Stwcar The ZX-10R 17 02-12-2009 12:05 AM
weird rocketracermike The Out House 6 02-26-2008 03:09 PM
A little weird RickRoush03 The Out House 14 02-14-2007 08:24 AM
