Gen 1: 2004-2005 weird gear problem - Kawasaki ZX-10R.net
post #1 of 8 Old 07-27-2014, 10:10 PM Thread Starter
OxyG3nE's Avatar
weird gear problem
Race Bike was working fine yesterday and today when i turn the ignition switch on i have the gi pro freaking out switching from 0 to 4 with clicking noise none stop. It also change to 5 or 6 sometime but always switching back and forth.. And in the same time the fuel pump is not priming.. Its probably related but i rémove the gear indicator and out the wire back and when ichecj my bazzaz its still doing it. The only thing that i did is wash the bike ..
OxyG3nE is offline
post #2 of 8 Old 07-27-2014, 10:42 PM
TechX's Avatar
Sounds like some electrical component doesnt like being wet. Let everything dry out and see if the problem persists. With the fuel pump not priming its probably the bazzaz.
TechX is offline
post #3 of 8 Old 07-28-2014, 10:07 PM Thread Starter
OxyG3nE's Avatar
Everything is very dry .. Opened dverything yesterday to let it dry .. Good thing i had my B bike for the track...
OxyG3nE is offline
post #4 of 8 Old 07-28-2014, 11:53 PM
TechX's Avatar
Do you still have the problem
TechX is offline
post #5 of 8 Old 07-29-2014, 09:14 PM Thread Starter
OxyG3nE's Avatar
yep same thing... im back from the track now.. gonna start taking it appart tomorow and try the spair harness i have .. also the gear switch thing i have in spair..
OxyG3nE is offline
post #6 of 8 Old 07-29-2014, 09:27 PM
bluedevil's Avatar
that seems very excessive at this point or desperate for a resolution....try and use the manual why something isn't working and even ask for help here after that......you could have water in a Joint connector and that would make sense but I would try old fashion trouble-shooting first before I start replacing a Whole wiring harness.
Bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #7 of 8 Old 07-29-2014, 09:46 PM Thread Starter
OxyG3nE's Avatar
haha i allready checked everything by the manual .. it was raining all first day at the track.. so now its pretty much naked so wont take much time :p
OxyG3nE is offline
post #8 of 8 Old 07-30-2014, 09:57 PM Thread Starter
OxyG3nE's Avatar
seem like it was 2 separate thing that happen... the gear indicator going crazy was probably water in the connection.... and the fuel pump not priming is the tip over sensor... I checked it but look like wasnt carefull enough... i didnt felt but maybe in the transport to te track ... ! Now i have to swap everything from my street bike to race bike ... Damnnnn
OxyG3nE is offline
Gen 3: weird problem zxryder85 The ZX-10R 6 01-27-2013 10:50 AM
weird starting problem.. I like saki Performance and Tech 6 06-21-2009 04:49 PM
Weird 5th gear shifting/problem Adr3naline fix Performance and Tech 36 09-02-2008 10:32 PM
Weird starting problem, help! Ridefly Performance and Tech 11 12-16-2007 05:58 PM
Need help with weird brake bleeding problem Lawdog78 Performance and Tech 5 03-30-2007 03:17 PM
