water wetter and winterizing - Kawasaki ZX-10R.net
post #1 of 4 Old 11-24-2009, 08:46 PM Thread Starter
evallarta1's Avatar
This was my first season with water wetter and after reading I know I have to pull it out before it gets too cold and freezes. My question is can I leave the bike empty after I pull the water wetter? Or do I need to fill it with anti-freeze?
Velocity Calibrations
evallarta1 is offline
post #2 of 4 Old 11-24-2009, 09:10 PM
Supercharged Mod
You can leave it empty. Aluminum exposed to air inside the cooling system won't corrode any faster than aluminum exposed on the outside of the engine. If you leave it empty, put a piece of tape over the ignition switch and write "NO COOLANT" on it ...
GoFaster is offline
post #3 of 4 Old 11-24-2009, 10:26 PM Thread Starter
evallarta1's Avatar
thanks for the idea GoFaster, also should I leave the cap off to let it air out?
post #4 of 4 Old 11-24-2009, 10:47 PM
I don't know anyone that leaves it empty. Maybe we are all just stupid, but refilling with antifreeze and bringing it up to temp; removing the air is part of winter maint. I do know several that save the antifreeze from year to year.
TN10R is offline
water wetter quantity ? limegreenbloodz Performance and Tech 4 06-19-2008 09:20 AM
How much Water Wetter to Use? IcePick06 Performance and Tech 4 06-29-2006 08:29 PM
Engine Ice or water wetter? kwakzx10r Performance and Tech 0 01-08-2005 09:33 PM
Water Wetter? zx10ragentblack Performance and Tech 6 10-13-2004 02:29 PM
Water Wetter mods2come The ZX-10R 3 06-28-2004 01:59 PM
