Warranty covered buzzing on 06 - 10r - Kawasaki ZX-10R.net
post #1 of 30 Old 08-18-2006, 03:08 PM Thread Starter
vegas10r's Avatar
Smile Warranty covered buzzing on 06 - 10r
I have had a buzzing somewhere in the ignition switch area of my 06 10r since about 500 miles...after 2600 miles it has progressively gotten worse.
Here is the skinny from Kawasaki here in Vegas...the round bolt heads that mount on the bottom of the ignition switch are the problem...the bolt heads are sheared off at the manufacturer to reduce chances of theft from this location...Kawasaki is going to fix the problem under warranty coverage by sending new bolts which will be installed.
pictures attached for the bolt location
vegas10r is offline
post #2 of 30 Old 08-18-2006, 03:30 PM
sure send pics if you could. im curious to see if your bolts look like mine. i have only noticed a buzz when gas is near empty
deezuhl is offline
post #3 of 30 Old 08-18-2006, 03:35 PM
sneaky's Avatar
Sounds like the Torque to Shear rating on those bolts heads are too low allowing the bolt heads to shear off at low tension causing the ign cylinder to become loose.
It is not a bad job, pull the upper drill out the old bolts and replace with new ones.
sneaky is offline
post #4 of 30 Old 08-18-2006, 03:39 PM Thread Starter
vegas10r's Avatar
I have to find my digital - pictures soon
vegas10r is offline
post #5 of 30 Old 08-18-2006, 04:11 PM Thread Starter
vegas10r's Avatar
the bolt heads are sheared off at the factory...the mechanic told me he can't tighten them up without new bolts...kawi already had previous calls about other bikes with the same problem...i am still looking for my camera for pics
vegas10r is offline
post #6 of 30 Old 08-18-2006, 06:47 PM
if they are sheared how the F*** are they gonna change them? boy thats gonna suck:headshake
T3MPO is offline
post #7 of 30 Old 08-18-2006, 07:10 PM
I'd just get the bolts and do the job myself....
Sands is offline
post #8 of 30 Old 08-18-2006, 07:19 PM
I hope to the sweet lord that that is the fix and that i don't have to ride anymore with that buzzing noise. it drives me insane.
LOU_DIAMONDS36 is offline
post #9 of 30 Old 08-18-2006, 07:24 PM
i have it too but its not that bad. i would get it fixed tho
T3MPO is offline
post #10 of 30 Old 08-18-2006, 08:37 PM
I have had the same problem with mine and the only way I was able to fix it was to install a boz bros exhaust! But still can hear once in a while over the pipe if you can believe that.
FERD is offline
Buzzing Sound Stopped - Now a new soundwhat is this sound zx10x2 The ZX-10R 2 06-21-2006 01:12 AM
Foot Peg Not Covered ZX14Pilot The ZX-10R 25 04-10-2006 08:54 AM
Warranty? Zega The ZX-10R 8 03-29-2006 10:47 AM
where is all the buzzing coming from on my ZX10? busaforhire The ZX-10R 42 02-02-2006 11:49 PM
Warranty ??? mad-kaw Performance and Tech 8 01-13-2006 04:10 PM
