Gen 2: 2006-2007 want more top end out of my turbo zx10r - Kawasaki ZX-10R.net
post #1 of 13 Old 08-27-2012, 11:01 PM Thread Starter
chucks ss's Avatar
ok so this is bad but after i got the turbo onthe bike , 189 mph comes way way way to fast and the bike wants so much more , i dont want to go with a gear setup for like the salt flats , this bike is a street bike, but i have to have more top end , what if i dropped the rear 2 and went up 1 in the front , would that be a good combo , , is there a system for the front and the rear sprocket ? or should i say rule of thumb ? id really like to see over 200and then some i dont want to loose too much low end though so , any thoughts would be great
2011 zx10r my new toy
(Wrecked )06 zx10r solar yellow , throttlemans 1/5 insert , healtech gipro with artre ,power commander usb yoshi r22 blings ,swing arm extensions 4 inches and last but not least velocity stage 1 turbo
chucks ss is offline
post #2 of 13 Old 08-27-2012, 11:27 PM
Post Whore
-Op-'s Avatar
what gearing do you have now?
-Op- is offline
post #3 of 13 Old 08-27-2012, 11:29 PM
johnnyflash's Avatar
189mph + street bike - why would you want more top end ?!
-rear and +front will get you more top end speed but you will loose pick up at the bottom end. This can make a bike hard to live with when riding on the street especially with turbo lag.
-2 rear and +1 front is a big step in gearing (about the same at -4 or more in the rear),so why not try +1 first (cheap mod) and see how it goes from there?
johnnyflash is offline
post #4 of 13 Old 08-27-2012, 11:34 PM
Post Whore
-Op-'s Avatar
I had the same thoughts to begin with but wanted to see where he was already with gearing. Also, the speedometer will stop at 186 or 189, right around there.
Chuck, are you GPS'ing your speed to see what the actual speed is?
I would try stock gearing and see how you like that, if youre not there already. If not, +1 front OR -2 rear. Not both though. Youre going to lose a fair amount of bottom end feeling with that kind of gearing though.
-Op- is offline
post #5 of 13 Old 08-27-2012, 11:42 PM
sam_b03's Avatar
gearcommander.com is your friend.
I agree baby steps. When tuning change one thing at time. It makes it easier to see what your doing. Change the front sprocket first because it changes largest effect. If your want more or less gear you can always go a tooth in the either direction in the rear.
my gen2 is geared down and will read 189 and stop. GPS it to find out what your actually doing.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #6 of 13 Old 08-27-2012, 11:57 PM
thundercoupe9's Avatar
I've got an 18 tooth front sprocket and 39 1st gen rear sprocket for more top end, they are available, look them up.
thundercoupe9 is offline
post #7 of 13 Old 08-28-2012, 12:25 AM Thread Starter
chucks ss's Avatar
im running stck gears . not gps jusr spedo reading . the question ! why more? its got a turbo lol but just my preference
post #8 of 13 Old 08-28-2012, 12:28 AM Thread Starter
chucks ss's Avatar
like.the idea go up 1 in the front and see how that goes . small steps
post #9 of 13 Old 08-28-2012, 06:02 AM
Post Whore
-Op-'s Avatar
definently give the +1 a shot, and get your speed GPS'ed too because it stops reading at 189 no matter how much power and gearing you throw at it.
-Op- is offline
post #10 of 13 Old 08-28-2012, 09:00 PM Thread Starter
chucks ss's Avatar
yea it sucks it only reads up to 189 , so gonna check into something that will be permantally on the bike for true speed
Zx10r turbo pic's sideshow Performance and Tech 52 08-20-2016 08:40 PM
does anyone have a 06-07 zx10r turbo chucks ss Performance and Tech 37 05-19-2016 11:46 PM
zx10r turbo mattyzx10RTURBO The ZX-10R 49 03-03-2011 07:52 PM
ZX10r Turbo martek Performance and Tech 68 12-05-2009 09:37 PM
Zx10r turbo sideshow Welcome Newbies! 16 06-24-2009 12:12 PM
