Walbro fuel pump mod - Kawasaki ZX-10R.net
 1Likes
post #1 of 69 Old 07-21-2007, 02:49 PM Thread Starter
Vince10R's Avatar
I finally spent the time to make the walbro GSS342 pump work. Although it is not a direct bolt in it doesnt take a whole lot to make it work. After disassembling the pump you have to use a razor blade to remove the extra material on the inside of the rubber isolator at the bottom of the pump Next, using a razor blade and a file I had to remove the four tabs on the bottom of the pump.
Last edited by Vince10R; 07-21-2007 at 02:58 PM. Reason: not sure how pics were working
Vince10R is offline
post #2 of 69 Old 07-21-2007, 02:54 PM Thread Starter
Vince10R's Avatar
then I had to shorten the regulator to make room for the wiring. Then I soldered up new wiring using spade connectors and eyelets and reassembled. Took bike for a ride and all is well.
Vince10R is offline
post #3 of 69 Old 07-21-2007, 04:27 PM
FAF
Rent this space
Very goodly, did you check the flow ??
FAF is offline
post #4 of 69 Old 07-21-2007, 04:30 PM
FAF
Rent this space
Vince, I have one question, did you buy the walbro with the in and out inline with each other or opposites ??The standard is inline and I was wondering wether the rubber gasket was inline with the relief hole.
FAF is offline
post #5 of 69 Old 07-21-2007, 05:43 PM Thread Starter
Vince10R's Avatar
I did not check the flow because I dont have anything to do it with. I did have it at 13000 rpms at wide open throttle without missing a beat. They claim it flows 255L so I think it will be plenty for just about any zx-10 without a turbo.
Vince10R is offline
post #6 of 69 Old 07-21-2007, 05:45 PM Thread Starter
Vince10R's Avatar
Yes its the straight through pump.(both inlet and outlet are inline not staggered) Which rubber gasket and relief hole are you refferring to?
Vince10R is offline
post #7 of 69 Old 07-21-2007, 06:18 PM
FAF
Rent this space
There is a small relief vent on the bottom of the pump that lines up a hole on the rubber spacer, if you have the straight through pump , as you do, it lines up fine.
FAF is offline
post #8 of 69 Old 07-21-2007, 06:28 PM Thread Starter
Vince10R's Avatar
The new walbro pump does not have that hole where the factory one does. I just took a look at it to make sure I didnt miss something.
Vince10R is offline
post #9 of 69 Old 07-21-2007, 06:50 PM
FAF
Rent this space
Splendid.
It looks like a small pressure relief system for the pump, I havent disected the old one yet to have a look.
FAF is offline
post #10 of 69 Old 07-22-2007, 03:32 PM
dsabat's Avatar
Nice job, glad it worked out for you. -Dean
dsabat is offline
FUEL PUMP for 04-05 zx-10R kneedraggin Parts, Gear and Accessories 1 05-04-2007 01:26 PM
bad fuel pump sweetride10r Performance and Tech 8 03-26-2007 02:25 PM
help with 636 fuel pump reckless1 ZX-6R & ZX-6RR Archives 5 06-08-2006 10:57 PM
fuel pump not on reckless1 ZX-6R & ZX-6RR Archives 0 06-08-2006 05:42 PM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
