vortex rear sets, rear brake light preasure switch not same a s plug - Kawasaki ZX-10R.net
post #1 of 3 Old 07-03-2010, 09:55 PM Thread Starter
I have vortex rear sets and just moved to PA, they require an inspection and of course, I didnt have the rear brake light hooked up due to the aftermarket rear sets, I got the vortex rear light switch, just rebleed my brake and am not in the process of running the wires to the plug, the connections are completely different, can I just cut the wires and splice them on the the ZX10 original plug wires???? I need help....
sch2046 is offline
post #2 of 3 Old 07-03-2010, 10:16 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
YES you should be able to just wire it directly if needed or not even use it and next time during the "inspection" just hit the front brake while you do the rear so the light will still come on. i've rode without the rear brake switch for years cause 95% of the time you're on the front brakes as well as the rear or I mainly use the front to scrub off most of my speed, the rear for me is mainly trailbraking or at a light sometimes. this may not be for everyone but it's always worked for me.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #3 of 3 Old 07-03-2010, 11:58 PM Thread Starter
just finished..
I rarely use my rear brake, but PA has this inspection that has to be done. I just clipped the wires with the plug and clipped the wires on the actual Vortex wires and sodered and heat shinked them, works fine now.
sch2046 is offline
Rear brake switch install on vortex rearsets??? Neversatisfied02 Performance and Tech 10 05-23-2012 08:04 PM
WTB: Rear brake light switch for '04' ZX-10 highsider Wanted: Buy or Trade 0 04-01-2009 11:13 AM
Rear Brake Light Switch Spring aminal_99 Wanted: Buy or Trade 2 09-23-2008 11:35 PM
Rear brake spring with Vortex rear sets? Puckfu Performance and Tech 2 10-26-2007 04:49 PM
Attack rear set question-rear brake light switch? steves87 The ZX-10R 35 10-09-2006 04:47 PM
