views on the zx10r kayaba suspension - Kawasaki ZX-10R.net
post #1 of 21 Old 02-15-2005, 07:29 PM Thread Starter
simonkobejapan's Avatar
what do you guys think of your kayaba forks and shock?any complaints?ideas for improvement?good points concerning performance,looks etc?
any features youd like to see?
any info greatly appreciated!
cheers
simonkobejapan is offline
post #2 of 21 Old 02-15-2005, 07:56 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Talking
Never heard of it. Thats not sayin much though...
James 3:7,8
hillcountry10r is offline
post #3 of 21 Old 02-15-2005, 08:00 PM
Supercharged Mod
Quality of components seems OK but the stock settings are way off the mark. Too much preload and too much compression damping at stock settings. It would be nice to have most rider's preferences to be somewhere near the middle of the adjustment range rather than at one end.
Questions of how well the damper's valving matches requirements are best asked of someone who knows more than I do. After adjustment, it's good enough for me.
GoFaster is offline
post #4 of 21 Old 02-15-2005, 08:34 PM Thread Starter
thanks for the reply.appreciate it
post #5 of 21 Old 02-16-2005, 09:12 AM
I agree with go faster, this bike was not setup for a 160lb rider...I weigh 155 and have backed out my preload and backed out most of the compression. The rebound also needs to be turned in to slow the action down. I would like to see less stiction, improved valving, straight rate springs as stock, and high low adjustable shock...if I had my choice. Even the magazines said it "we want a ramped preload adjuster on the rear shock or easier access to the adjusting nuts, one of the two" And tell kawasaki to include a spanner in the tool kit!!!
Basically, I want yamaha suspension on a kawasaki frame and motor with eithers brakes.
Do you work for kayaba? After the 636 went to showa it will be interesting to see if the 10r also makes the switch. Not knocking kayaba but all the bikes you hear about with stellar front ends are showa (GSXR & Ducatis)
BNninja is offline
post #6 of 21 Old 02-16-2005, 10:31 AM
Big Daddy's Avatar
Images: 38
remove the top-out spring completely.
Big Daddy is offline
post #7 of 21 Old 02-16-2005, 04:24 PM
You done this?
sp500 is offline
post #8 of 21 Old 02-17-2005, 12:55 AM
I like the Kayaba setup on my 04 10R waaaaay better than the stock setup on my 04 636. The 10's rear shock actually does its job supporting my 205lbs without any wallow or drama. The forks have bad stiction if you back the preload out >= 5 lines showing and push them to 75% of travel. The stiction is less noticeable @ 4 lines and nonexistant w/ 3 lines of preload. I'm in no hurry to do Ohlins front/rear (I LOVE Ohlins forks BTW) because I can def. live with the stock components (at least thru my 1st race season).
SuicideMachine is offline
post #9 of 21 Old 02-17-2005, 02:03 AM
Erich's Avatar
It would be nice if all their adjusters were position versus click type. Their is no greater annoyance than being between clicks. Or if the must, have finer adjustment increments other than the 1/8 turn or 1/4 turn versions.
Why is it that a proper valve stack can't be used. All that high speed compression is just unnecessary. A higher flow valve as in the showa would be nice and help with the comp and rebound crosstalk. And lower the hydraulic bottom out area.
Out back, what is up with the crazy amounts of rebound the newer socks have?
Personally I like rear spring collars as they are more adjustable and you're not locked into where the ramp step leaves you.
Erich is offline
post #10 of 21 Old 02-17-2005, 06:51 AM
Question for your friend at Kayaba. Does he know why Kwak (or possibly Kayaba) went with a front axle setup that pinches the forks together, and creates so much stiction? I haven't seen another sport bike do this in years.
CanyonCarver is offline
Settin Suspension Sag hillcountry10r Performance and Tech 20 02-07-2007 04:31 AM
Settin Suspension Sag hillcountry10r How To... 2 02-05-2005 02:29 PM
ZX10R Suspension setup stanmann The ZX-10R 13 06-30-2004 12:42 AM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
Some driving test`s with the ZX-10R Mike_P Netherlands Archives 16 01-07-2004 12:10 PM
