Very slight head shake - Kawasaki ZX-10R.net
post #1 of 58 Old 04-21-2006, 04:18 PM Thread Starter
fastburnzx-10's Avatar
Send a message via AIM to fastburnzx-10 Send a message via MSN to fastburnzx-10
Had the 10 out today and tried out the new 190/60 hill sold me...DAMN I love that tire Hill...Anyway I dunno if it is from sitting all winter on a kickstand (didnt have the stands yet) mabey the front tire is flat spotted.. but at about 100-120 under moderate acceleration i have a lil head shake.... It never did that before, and my tire pressures are all right on the money at 36 front and 42 rear.... Has ne one heard of or experienced it? Any help would be appreciate it
Any help would be
Ride hard, ride fast....
08 ZX-10R (Black)
05 zx-10r (magma)-KIA---
73 Z1 900 (all original)-The Original Kawi beast
fastburnzx-10 is offline
post #2 of 58 Old 04-21-2006, 05:47 PM
Big Daddy's Avatar
Images: 38
yes the 10 can exhibit some flighty frontend behavior that can turn into head shake no matter what tires are on it however the 190/60 changes the geometry a fair amount (raises the rear) so be careful. 42 cold psi is a bit high especially for a DOT race tire which i'm guessing this is.
Big Daddy is offline
post #3 of 58 Old 04-21-2006, 05:50 PM Thread Starter
its a 209gp... i looked today after work and the rear chain adjust. was just a little bit off..so i straightend it up but it started rain so i dont know if that was it too....although i havnt experienced it real bad again since the first day i had it out....what tire psi would you recommend?
08 ZX-10R (Black)
post #4 of 58 Old 04-21-2006, 05:55 PM
Big Daddy's Avatar
Images: 38
Since this is primarily a track/race tire and those are the conditions its typically used under therefore the cold PSI range is 29-31 but since your using it for street duty try 35 and see how it feels. The lower you go with most tires the quicker it wears, hence mileage sucks.
post #5 of 58 Old 04-21-2006, 05:57 PM Thread Starter
i have a another bridgestone.... in 190/50...
but ill run the 190/60 for a lil while adj the pressures and see what happens...thanks man really appreciate the help
08 ZX-10R (Black)
post #6 of 58 Old 04-22-2006, 04:25 AM
mach_man_187's Avatar
yea, what BD said!!!!
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #7 of 58 Old 04-22-2006, 10:21 AM
Tire pressure for the 209GP: 30/30. If it's cold outside, 29 rear. Headshake will reduce with proper pressure, and lowering the rear a little will help a lot, too. 42psi is way too much.
CanyonCarver is offline
post #8 of 58 Old 04-22-2006, 11:52 AM
Dragone's Avatar
Images: 11
:iamwithst
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #9 of 58 Old 04-22-2006, 07:19 PM
norcal10's Avatar
did some hard riding yesterday on a favorite road, and i noticed (for the first time) so slight shake when i'd jump on the throttle coming out of corners. i had my pressures at 32/32, with the stock tires. is this normal? do i just need a damper? i've heard you can tighten the stem nut a little, what is the recommended ft.lbs? thanks guys. btw, a damper is in the works.
norcal10 is offline
post #10 of 58 Old 04-22-2006, 07:41 PM
Dragone's Avatar
Images: 11
Na, get used to it when riding aggressive. A little twitch is a good sign that you are exiting correctly. Tells you about your suspension and exiting.
Dragone is offline
HEAD SHAKE - HELP A Brother out speed4life Performance and Tech 3 02-08-2006 12:42 PM
Head Shake!!!! jarhead05 The ZX-10R 52 01-17-2006 08:25 PM
Severe head shake? maze The ZX-10R 48 04-02-2005 08:58 AM
Head shake GARSZX10R Performance and Tech 26 12-07-2004 02:42 PM
Head shake FrEteGi The ZX-10R 15 04-09-2004 08:13 PM
