Gen 4: 2011-2015 Very loud squeal under tank - Kawasaki ZX-10R.net
post #1 of 14 Old 08-23-2014, 09:31 AM Thread Starter
Bry
Bry's Avatar
2011
Mods: Akra slip-on, PC5, Guhls ECU flash, K&N filter
Symptoms:
-Had a slight stumbling feeling a few days ago. Lasted 5 seconds, maybe. Roads were wet and I chalked it up to the TC. A few minutes prior though, my fuel light came on so I stopped and got a full tank of gas: 93 octane.
-Did the stumbling again today on my way home, however it didn't quit. Same tank of gas. 10-ish or so miles from fuel light coming on. Started sounds like a v-twin. Found the closest parking lot and pulled in and it shut off on it's own. Can smell the fuel.
-I let it sit for a few minutes and tried to restart once, but it made a very loud squealing sound from underneath the tank after the 2nd crank. Pushed it home.
3,100 miles...all fluids changed within the last 1,100 miles. I do have a 2 year, $0 deductible warranty. It was dark by the time I got home, so I didn't lift the tank to peak around. And quite honestly, I bought the warranty so I don't have to screw with it. I am mechanically inclined however.
FI light never came on at all.
I did find the Sticky involving dropping power/cylinder issue in regards to the PC5 firmware update.
Does this sound like a PC5 firmware problem, or the fuel pump?
'11 10R
'07 GSXR 750
Bry is offline
post #2 of 14 Old 08-23-2014, 07:57 PM
Chris99sleeve's Avatar
My guess would be fuel pump. Pull the tank off yet? I know there's a thread on how to measure the fuel being pumped out to see if the pump is weak. Maybe search that.
Chris99sleeve is offline
post #3 of 14 Old 08-23-2014, 08:20 PM
SkyDork's Avatar
Exactly. Sounds like the fuel pump is bad. Noise under the tank and poor running = probably the fuel pump.
#WordCrimes
SkyDork is offline
post #4 of 14 Old 08-24-2014, 10:25 AM Thread Starter
Bry
Bry's Avatar
I did come across that thread some where.
Lifted tank, disconnected PC5, problem persisted.
Immediately after it happened I assumed fuel pump. But once I started searching around, I read other threads about the PC5 firmware. In my past experiences, the fuel controllers (if installed) have always been my first step in solving rough running bikes. It helps to isolate a fueling issue.
My next question is in regards to the warranty, and it may be a silly question but the idiot asks no questions, since the bike has a PC5 (a fuel device) would it affect the dealer replacing the fuel pump under warranty? Fuel pump...fuel controller...they're at least in the same ball park.
'11 10R
'07 GSXR 750
Bry is offline
post #5 of 14 Old 08-24-2014, 11:00 AM
GREENDEL's Avatar
Lightbulb Is the issue related to
This may sound crazy to some. But if I was to take it to the stealership, I would remove the PCV 1st. Why? 3 reasons. 1.) If it is the PCV you would know immediately after removing the PCV and starting it 2.) If it is the PCV and the shop locates the problem in the PCV you will be charged for their service, because the problem was not a part of the original bike warranty. 3.) If you remove the PCV and problem persists then you know the Problem is not the PCV and they are fully responsible for correcting the issue. If the shop has any suspicion that the problem is not their responsibility they will not take any responsibility for the problem resulting in $ from your pocket. IMHO as always. Just my 2 cent. Hope this helps in some way.
What did she say? - She Lida da soup!!
GREENDEL is offline
post #6 of 14 Old 08-24-2014, 11:14 AM Thread Starter
Bry
Bry's Avatar
I did unhook the PC and the problem still persisted. But I'm picking up what your laying down. That's my main concern with taking it to the stealer as well.
'11 10R
'07 GSXR 750
Bry is offline
post #7 of 14 Old 08-24-2014, 11:15 AM
SkyDork's Avatar
This. Remove the PCV and try it. There's no warranty issues that way either. The can deny warranty if aftermarket parts are found to be a contributing factor.
And I can pretty much tell you that a solid-state device like a PCV won't make a loud squealing sound, so you can pretty much rule that out as the cause. At least I would.
#WordCrimes
SkyDork is offline
post #8 of 14 Old 08-24-2014, 12:07 PM Thread Starter
Bry
Bry's Avatar
As I mentioned, the problem remained even when I unhooked the PC, however I think I'm just going to take it off anyways. I really don't want to run into any problems with the dealership about it. It's one less thing for them to point the blame at.
Thanks for the advice guys!
'11 10R
'07 GSXR 750
Bry is offline
post #9 of 14 Old 08-24-2014, 12:25 PM
Misleadb4's Avatar
Had same issue on mine without the squealing noise. Ended up i got a bad batch of gas and had a dirty air filter, and it fouled 3 plugs. Changed plugs, air filter, and treated the tank for bad gas. Never had the problem again.
Take it to Kawi and see waht they say. Thats your best bet.
'06 CBR 600RR Retired
'05 CBR 1000RR Retired
Gen 4 ZX10R Black De-Badged, Flashed, Competition Wereks Exhaust, PCV, K&N Race Filter, 1/5 Riflemans insert, Afam sprockets 16t front 41t rear, Zero Gravity Windscreen, Yoshimura Fender Eliminator,Vortex Frame Sliders, Luimoto Monster Edition Seat Covers With Gel Inserts, Beloved by All, Rode Hard Put Up Wet Daily.
186 WHP Dynoed 07.12.14 Blias Cycles Dania FL.
The person thats says it can't be done should not interupt the person doing it.
Misleadb4 is offline
post #10 of 14 Old 08-24-2014, 12:41 PM Thread Starter
Bry
Bry's Avatar
Will do. Thanks!
'11 10R
'07 GSXR 750
Bry is offline
BMW brake squeal.... prowler General Motorcycle Discussions 7 05-19-2012 08:53 AM
How loud is too loud?? eclecticrider General Motorcycle Discussions 6 04-08-2008 07:26 AM
Squeal frustration Vehicle 1 ZX-6R & ZX-6RR Archives 3 11-14-2007 08:49 AM
2004 zx10 and squeal noise? playlife4fun The ZX-10R 18 10-12-2007 09:33 PM
How loud is it? Darren797 The ZX-10R 17 08-07-2006 03:15 PM
