Gen 1: 2004-2005 velocity stacks - good or bad? - Kawasaki ZX-10R.net
post #1 of 13 Old 08-29-2012, 01:52 PM Thread Starter
Question velocity stacks - good or bad?
I knew that velocity stacks have been changed on my bike by the previous owner but could not have a chance yet to check them.
Today I changed my air filter and took a few pictures inside the air box.
Here is what I found. What do you think? Is this good or bad that I found?
giszo is offline
post #2 of 13 Old 08-29-2012, 02:08 PM
Quick10's Avatar
Looks like some custom made ones. I've not seen any that look like those. The taller stacks will give a boost to the midrange.
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #3 of 13 Old 08-29-2012, 02:26 PM Thread Starter
The two outer ones look a bit hackish to me as they were cut a little to fit inside the airbox.
That is why I thought they are worse than the original ones but unfortunately I am not really an expert on this area.
giszo is offline
post #4 of 13 Old 08-29-2012, 02:27 PM
formerly GHOST RIDER
SOUN1's Avatar
Who does the bike respond to the throttle? Do you have a PC ? If not, then your bike is not runnung normal. Is your bike sluggish at the start? I had 3 sets made for my 05 (different height) and never got it running right w/o a PC. The v stack does make the bike sound evil as hell tho.
Never forget who helped you!
Never forgive who fu*ked you.
Doing a trackday is like "SEX", no matter what happens you'll want to hit it again..
SOUN1 is offline
post #5 of 13 Old 08-29-2012, 03:11 PM Thread Starter
I have no PC on the bike yet.
giszo is offline
post #6 of 13 Old 08-29-2012, 03:16 PM
Supercharged Mod
Even the stock velocity stacks are cut away slightly to clear the airbox side walls.
Looks like these were made with a taper rather than a bell-mouth curve. Not ideal, but the difference between this and the ideal shape is likely too small to notice.
My money is on "doesn't make any difference" in this case.
GoFaster is offline
post #7 of 13 Old 08-29-2012, 03:23 PM
SOUN1's Avatar
I would just go get the stock stacks and compare the two as to see how the bike responds. Like you say, you don't have a PC at the moment, my money will be on going with stock stacks and your bike will be running better.
SOUN1 is offline
post #8 of 13 Old 08-30-2012, 01:53 AM Thread Starter
Thanks for the input, guys!
I will try to grab a set of stock velocity stacks and do some kind of comparison.
giszo is offline
post #9 of 13 Old 08-30-2012, 09:08 AM
keithk's Avatar
They look really nice I would leave them but clean all those dead bugs and crap out of there where the filter goes!
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #10 of 13 Old 08-30-2012, 09:48 AM Thread Starter
Of course I cleaned the dead things before installing the new filter.
giszo is offline
velocity stacks FTHOODZX10R ZX-14 Discussion 4 05-19-2011 05:11 PM
Velocity stacks Older Guy The ZX-10R 78 03-11-2009 10:16 AM
06 velocity stacks boriqua935 The ZX-10R 3 09-08-2006 03:31 PM
Anyone tried Velocity stacks yet? BNninja Performance and Tech 9 10-29-2004 02:15 PM
velocity stacks greenmeanie The ZX-10R 10 09-27-2004 06:49 PM
