Valve Cover Gasket - How Reuseable Is It - Kawasaki ZX-10R.net
post #1 of 10 Old 03-13-2011, 03:47 AM Thread Starter
Hey Folks,
I'm in the process of doing a valve check and I'm curious if the valve cover gasket is reuseable and if it is reuseable how many times can you reuse the same gasket? I bought this bike second hand and I'm not sure if the gasket was ever reused so I'm abit curious if I might be able to get away with using the same one. If I do reuse the same gasket, do I use a gasket sealer along the whole surface. In the service manual it looks like the gasket sealer is only where the camshafts lay.
Thanks
muggz is offline
post #2 of 10 Old 03-13-2011, 03:52 AM
Licensed Dist of HaterAde
TMY10ER's Avatar
Me personally man, i'd replace it if at all possible.....i've re-used gaskets on side covers and in conjunction with sealer BUT on the valve cover, if that bitch leaks then it seems like a shit ton of work just to replace it AGAIN. just my 2 cents though.
TMY10ER is offline
post #3 of 10 Old 03-13-2011, 03:53 AM
NinjeR's Avatar
replace it, it's only a 17 dollar part. And it's a known seal to leak on the gen 1.
NinjeR is offline
post #4 of 10 Old 03-13-2011, 03:54 AM
tasos's Avatar
The valve cover gasket is notorious for leaking on Kawis especially after opened, you should be safer changing it.
tasos is offline
post #5 of 10 Old 03-13-2011, 04:00 AM Thread Starter
Alright, I'll go ahead and order one. I've just read of others reusing thats why I ask. Also when I install the new gasket can someone provide me clarification on the gasket sealant. In the manual it looks like I only bead it where the camshafts lay O.o
Advice?
muggz is offline
post #6 of 10 Old 03-13-2011, 04:03 AM Thread Starter
Where can I order one for $17.00? I'm about to order from Bikebandit and its listed as $37.69
Thanks
muggz is offline
post #7 of 10 Old 03-13-2011, 04:04 AM
tasos's Avatar
Just put a very thin layer in the remaining head surface for a piece of mind.
tasos is offline
post #8 of 10 Old 03-13-2011, 04:11 AM Thread Starter
Will do.
Thanks
muggz is offline
post #9 of 10 Old 03-13-2011, 04:17 AM
NinjeR's Avatar
Thanks
Guessed they raised the price by 10 bucks...it's 27 here, used to be 17
http://www.ronayers.com/Fiche/TypeID...der_Head_Cover
NinjeR is offline
post #10 of 10 Old 03-13-2011, 11:09 AM
Teeks's Avatar
I have done 2 of these recently. Make sure if you are not going to use rtv that you order new grommets for the valve cover mounting bolts as well, they do not come with the gasket. I have done 2 of them recently, one with new gasket, black rtv, and no new grommets, its been holding perfect for over a month. I just did my bike like a week ago, i re-used the gasket and added rtv as well, seems to be fine.
Teeks is offline
valve cover gasket leaking bradshow01 ZX-12R Discussion 12 02-26-2013 05:52 PM
valve cover gasket question livefreeordie10r The ZX-10R 15 07-10-2009 06:49 PM
Valve cover Gasket blackisfaster Performance and Tech 1 05-01-2008 03:31 AM
Valve Cover Gasket Slims10R Performance and Tech 15 12-27-2005 09:53 AM
Leaking Valve Cover Gasket!!! zx10ragentblack Performance and Tech 11 09-14-2005 02:51 PM
