Valve clearance - Kawasaki ZX-10R.net
post #1 of 3 Old 05-10-2007, 08:55 AM Thread Starter
Valve clearance
Anybody know the valve clearance adjustment for intake and exhaust.
For 2004 zx-10r, and it's not the same number for 2006 where the valve clearance number change...
So thanks.
ninja_12r2000 is offline
post #2 of 3 Old 05-10-2007, 09:29 AM
maze's Avatar
Standard:
Exhaust- 0.17-0.22mm or 0.0067- 0.0087in
Intake - 0.15-0.24mm or 0.0059-0.0094in
Race:
Intake- 0.22mm
Exhaust- 0.20
Squish - 0.85
The only thing nessecary for the triumph of evil is for good men to do nothing
"sometimes in order to truly live life you must risk it."
You hit the lights, I hit the gas...
THERE ARE ONLY THREE SPEEDS, FAST, VERY FAST, AND OH SHIT!
maze is offline
post #3 of 3 Old 05-11-2007, 07:23 AM Thread Starter
Valve
Anybody try to adjust they're valve ???
Now on this model did I have to remove the radiator ???
Did I need to detach the motor from the frame.
They're a lack of space, even the rubber mat seem a little bit hard to pull out. Did we got a book somewhere on line for this mechanic of zx-10r (2004) ???
Valve Clearance Philosophy CanyonCarver Performance and Tech 22 09-18-2017 10:27 PM
Valve clearance ranges caboose Performance and Tech 10 02-15-2007 09:12 PM
valve clearance job nobody Performance and Tech 45 05-30-2006 08:45 PM
valve clearance procedure nobody Performance and Tech 4 04-11-2006 08:36 AM
Valve Clearance hillcountry10r Performance and Tech 41 12-20-2005 08:18 PM
