Gen 2: 2006-2007 Valve adjustment on a gen2 - Kawasaki ZX-10R.net
post #1 of 5 Old 07-04-2014, 11:56 PM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
Send a message via AIM to ZiG 9th
About to do the valve adjustment an put a new valve cover gasket on. Does the engine have to come out or get dropped down?
<img src=http://i261.photobucket.com/albums/ii64/thebluehanger/Thriller.gif border=0 alt= />
Quote of the year! lol!!
"1 shut the fuck up 2 ur opinion doesnt count on this kind of page where saw fans come together 3 you fucking liked you own comment thats fucking pathetic!" -Brandon Welbig
ZiG 9th is offline
post #2 of 5 Old 07-05-2014, 09:10 AM
Shift_Nashville's Avatar
Damn, you live......where you been for the last umm forever?
I replaced my valve cover gasket a while back, only had to take off airbox, throttle bodies...make sure you follow the service manual torque specs on the valve cover bolts, they are very soft and break easily...
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #3 of 5 Old 07-06-2014, 04:17 AM Thread Starter
The Movie Goer!
ZiG 9th's Avatar
You didn't have to take the radiator off at all?
ZiG 9th is offline
post #4 of 5 Old 07-06-2014, 09:19 AM
keithk's Avatar
I just did a valve cover gasket on gen2 don't have to touch radiator but I did have to remove the right side ,if your sitting on the bike, motor mount to slide the valve cover out, also remember to mark the plug wires very easy to get 1 and 2 mixed up!
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #5 of 5 Old 07-06-2014, 02:08 PM
Gen 5 Now!!
08zx10rny's Avatar
nope. remove air box, throttle bodies, coils and probably the upper engine mounts. but have to drop radiator a little to get the rubber heat guard off the top of the motor
GEN 5!!!
08zx10rny is offline
Gen 3: Actually DOING the valve adjustment apollo240 The ZX-10R 5 09-13-2012 09:24 AM
Valve adjustment????? Spyda_ninja Performance and Tech 34 03-14-2008 06:13 PM
Valve adjustment? CP10R ZX-6R & ZX-6RR Archives 4 02-02-2008 05:10 PM
Valve adjustment done Tread70 Performance and Tech 24 10-18-2006 08:03 PM
valve adjustment on the 10 vegasdude The ZX-10R 2 05-28-2005 06:38 PM
