Using SpeedoHealer w/stock gearing?! - Kawasaki ZX-10R.net
post #1 of 23 Old 01-04-2009, 08:32 PM Thread Starter
ikaika's Avatar
Alright, I plan on changing my gearing later this year but was thinking about getting a SpeedoHealer now. Is the stock mph off that much? Would it be worth it to put it on now or should I wait till I change the gearing (-1 front)?
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 23 Old 01-04-2009, 08:36 PM
you have to calibrate the speedo healer, you would have to reset it when you changed gearing even if y ou put it on and set it now
zero4o3 is offline
post #3 of 23 Old 01-04-2009, 08:41 PM
Gang Green's Avatar
Yes, it is worth it.
Stock the speedometer is off around 6%. So, yes I think it is worth that. You won't be racking up the milage as fast either.
Rubber Side Down!!!
"Read The Signs"
God gave Rock'N Rolll to ya, and Kawasaki too!
Gang Green is offline
post #4 of 23 Old 01-04-2009, 08:59 PM
Postwhore with an 04
bcm0018's Avatar
I thought they were off more than that...round 8-10%
bcm0018 is offline
post #5 of 23 Old 01-04-2009, 09:14 PM
bluedevil's Avatar
It seems to NOT be linear for percentage the higher speeds you go but it's just more obvious at those speeds....the Suk guys are famous for this saying they can do 200mph but in reality the stock speedo really shows an incredible error in the Higher speeds STOCK especially on certain bikes...so yes a SpeedoHealer is a good idea.
bluedevil is offline
post #6 of 23 Old 01-04-2009, 09:24 PM
Gen 5 Now!!
08zx10rny's Avatar
i agree. about 8-10%. i had a gps hooked up to my 08 10r going to motogp in indy this summer and my speedo said 100mph when the gps was reading between 90-91mph.
GEN 5!!!
08zx10rny is offline
post #7 of 23 Old 01-04-2009, 09:35 PM
Post Whore
my 05 was about 10% off too
Nick.INF is offline
post #8 of 23 Old 01-04-2009, 09:39 PM
I thought I read somewhere the percent error was around 9.6%. I would definiately get the speedohealer....then you can set the change to 99.9% and ride around without adding miles to your bike or do vice versa for you tube videos and/or pics
killersrt is offline
post #9 of 23 Old 01-04-2009, 10:04 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Hahaha!
I wonder what the speedo will show at 99.9 %
Lucky10R is offline
post #10 of 23 Old 01-04-2009, 11:29 PM Thread Starter
ikaika's Avatar
Thanks for the help. I will be ordering the SpeedoHealer this week. I alreay got an awesome qoute from SuperbikeSupply, as usual. FYI, the SpeedoHealer online calculator shows a -5.2 calibration value when I select the "Estimated" method. I dont have a GPS , radar gun, or dyno to measure the speed so I did not select the "Precise" method.
ikaika is offline
04/05 SpeedoHealer % stock gearing & mounting ? themightymezzo Performance and Tech 21 03-06-2008 06:24 AM
I like stock gearing. curiousmike The ZX-10R 11 08-15-2007 09:09 PM
'03-'04 Stock Gearing? dnwhoop02 ZX-6R & ZX-6RR Archives 3 06-30-2006 01:28 AM
Stock gearing 06 10r TX06'10r The ZX-10R 2 06-29-2006 05:20 PM
speedohealer-gearing spreadsheet? speedfreak Performance and Tech 3 06-24-2005 12:59 AM
