Upgrading clutch? - Kawasaki ZX-10R.net
post #1 of 5 Old 04-11-2011, 01:25 PM Thread Starter
Upgrading clutch?
I need to do something with my clutch. I am not sure what... either change springs or change clutch but something has to be changed. When I launch my bike, I am getting severe chatter. I pull the clutch back in a tad and let it out and it seems to grab better and the wheel comes up. Happens every single time. I dont mind the wheel coming up, that issue can be addressed but the chatter issue is a problem. It either bogs, chatters, or wheel comes right up at the launch. There is no in between to float the clutch like I could do on other bikes and carry the front wheel from the launch until it settles.
Obviously we are talking about drag racing here. Stock clutch has about 4k miles on it. 07 ZX10R. Best I can pull is a 1.9 60' I have video of my launches to show you what I mean. You cn hear me launch the bike, I can feel it chattering then I slip the clutch back in a little and it slips and grabs nice.
If it matters, I am using a mobil1 syn 10-30 oil.
kkline_83 is offline
post #2 of 5 Old 04-11-2011, 01:35 PM
codyc_13's Avatar
First off make sure you clutch basket doesn't look like this
If it doesn't, Call dwayne at concept cycles and order a clutch for a 2004 zx10r WITH judder spring.
Or you could try soaking them in oil to see if it helps.
When you put the 04 clutch in DON'T put the 2 big washers back in.
codyc_13 is offline
post #3 of 5 Old 04-11-2011, 02:10 PM
Btrain87's Avatar
let's see the vids bro!
Btrain87 is offline
post #4 of 5 Old 04-11-2011, 02:32 PM
zx racer's Avatar
like codyc said check your basket to make sure you dont have any groves or notches in the basket where the plates fit. also a good upgrade i see alot of gen2 owners doing is switching out the stock basket for a gen1.
zx racer is offline
post #5 of 5 Old 04-15-2011, 02:30 AM
mrbzx7's Avatar
I welded my basket together to disable the slipper function, no more problems. I do have Barnett springs
mrbzx7 is offline
Gen 1: Upgrading the guage cluster PoisonIvy The ZX-10R 3 03-26-2011 11:35 AM
Thinking about upgrading from a Z1000 to a ZX10, thoughts? MisterMagoo Welcome Newbies! 25 08-25-2008 09:48 PM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendor Deals 2 09-25-2006 06:25 PM
clutch tank zx10r Vendor Deals 1 08-22-2006 08:07 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 04:13 AM
