Uneven fueling - Kawasaki ZX-10R.net
post #1 of 4 Old 06-29-2010, 02:48 PM Thread Starter
Uneven fueling
Hi,
Just joined (newbie) but had her for 18 months. I've had a look through the forum but can't seem to see any help!!!. Gotta say, this place is a wealth of info!!!
My problem, before I start stripping her (05 ZX10R) is uneven/fluffy fueling around town. She hunts whilst held on an even throttle in all gears, winding on to full chat isn't a problem. She'll pull 300Kph no probs!!
PCIII,running Dynotech map,K&N filter and Arrows full system, serviced 6 months/1500 kms ago. I asked for a major service and got charged for one, just wondering if I was stitched up?? Is this plugs, air cleaner or valve problem??
Has anyone had this before and can help??
Fed up surging through every town I come across!!
ZX10Rfurious32 is offline
post #2 of 4 Old 06-29-2010, 04:13 PM
gazx10's Avatar
fueling
sounds like your heading is your problem. plugs, air filters, and valves wont fix a fueling problem, you must address the fueling system. have your injectors cleaned professionally and flowed, or at least run a can of good fi cleaner thru your system, then custom map tuned to your bike. the change can be amazing.
gazx10 is offline
post #3 of 4 Old 06-29-2010, 10:11 PM
redline659's Avatar
Sounds lean down low. Have it retuned
redline659 is offline
post #4 of 4 Old 06-30-2010, 03:27 AM Thread Starter
Thanks both of you, for the advice!!
I'll get the fuelling looked at then and some more dyno time!!
05 Zx6r fueling problem JLG0987 General Motorcycle Discussions 9 07-04-2010 01:04 AM
05 Zx6r fueling problem JLG0987 General Motorcycle Discussions 3 06-24-2010 05:43 PM
***Uneven Rear Tire Wear INPUT PLEASE*** Solo-Six General Motorcycle Discussions 5 03-31-2010 05:27 PM
Rich fueling? Newbusa The ZX-10R 3 10-22-2007 08:20 AM
