Undertail HELP!!! - Kawasaki ZX-10R.net
post #1 of 5 Old 03-30-2006, 02:27 AM Thread Starter
Undertail HELP!!!
I am wantin to take my rear fender off and not have blinkers and everyone says "its just like four bolts" but I have heard that if you just unbolt it it will cause the tailpiece to crack if you dont put in "spacers" if someone could take pictures of where these spacers are supposed to go and what I should use for spacers I would be appreaciative thanks guys...
No-Mo is offline
post #2 of 5 Old 03-30-2006, 03:02 AM
Post Whore
Sgtusmc96's Avatar
Yes you do need someting to lift the bottom of the tail up like the rear fender did. Mine cracked and I got it warrantied and then fiberglassed the new one so it would not crack again.
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #3 of 5 Old 03-30-2006, 04:05 AM
pongo's Avatar
just put the two screws back in the tailpiece.
pongo is offline
post #4 of 5 Old 03-30-2006, 10:36 AM
Supraman78's Avatar
Images: 11
so the point is to lift the tailsection back up to the underside frame/trunk area?...I'm about to make some pieces to fit in the holes left by removing the crappy flap/turnsignal/plate assembly. Do I just make them screw into the stock holes? or do I need them to somehow connect to the rear fairing and maybe hold it up to the trunk area?
05 ZX-10R Green *SOLD* - Champs Frame Sliders, Swingarm Spools; Clear Alternatives Integrated Taillight; Clear Euro Signals; H7 Silverstars ; 1/5th Throttle Mod; Ivan's Block Off Plates; Hyperpro Steering Damper; OEM Solo Seat Cowl; Hindle Ti High Mount Exhaust shortened 4 in; SuperLED green running lights, LEDMods.net Green Speedo; GIPro gear indicator w/ TRE
Supraman78 is offline
post #5 of 5 Old 03-30-2006, 11:18 AM
i just bolted my license plate up to the stock holes using an L bracket. put all 4 bolts back in and voila. (on my '05)
Abortions Suck is offline
Lookin for a specific undertail for my 10 95blueoval The ZX-10R 9 03-17-2006 06:52 PM
Ghost Undertail Group Buy IcePick06 Vendors deals 30 11-28-2005 08:26 PM
ZX-10R Undertail Exhausts by Hotbodies Racing Punch The ZX-10R 32 07-01-2004 03:58 PM
New hotbodies undertail with pics, possible group buy????? liljunglist2 The ZX-10R 41 06-29-2004 01:30 PM
BallMoto Undertail woes............ RUNNINHORN The ZX-10R 21 06-11-2004 11:31 PM
