Twin headlight Help for '07 - Kawasaki ZX-10R.net
post #1 of 2 Old 04-19-2009, 05:29 AM Thread Starter
Firstly : Does anyone know if leaving your highbeam on all the time will cause any major problems?
Secondly : Has any one ever heard of a mod that adjusts the level of the high beam (vertical) ie some sort of servo that raises it with highbeam 'on' and lowers it when 'off'??
gskean is offline
post #2 of 2 Old 04-19-2009, 06:54 AM
sam_b03's Avatar
Leaving it on may wear the bulb from use so you may have to replace it or often not that many bikes get ridden enough to "wear out the light bulbs".
I have never heard of a mod for moving the bulb.
sam_b03 is offline
Tags
'07, headlight, mod, twin lights
ZX10R Twin desertchecker The ZX-10R 23 12-06-2008 12:08 PM
Help on V-Twin engine Kent Performance and Tech 8 11-13-2008 05:36 AM
How To: Install a Twin headlight Module unit. ninjasuz Test Area 9 05-05-2008 11:17 PM
TWIN ENGINE TWIN TURBO hundaj grego10r Pictures and Videos 4 11-17-2005 10:51 AM
From a Twin to a 10R .... vane The ZX-10R 58 08-23-2004 06:08 AM
