turn signal troubles - Kawasaki ZX-10R.net
post #1 of 6 Old 05-04-2008, 11:31 AM Thread Starter
i just bought me a 05 zx10r and none of the signals work it has power to the fuses and all the wires are hooked up but no power at the light i hooked the lights up directly to a hot wire and they work just wondering if this bike has a flasher like on cars and if so where is it thanks
poboy is offline
post #2 of 6 Old 05-04-2008, 11:43 AM
Images: 11
Hey welcome to the site POBOY and glad you're here, My bike is stored somewhere else right now :( otherwise Id go out and getcha a Definate answer but I can't now... Sorry but I do know there is a repair manual on here for the first generation try the search function for now... I have it downloaded too so I can email it to you in .pdf format if you want... Hope it helps
firerescue212 is offline
post #3 of 6 Old 05-04-2008, 11:57 AM
JOSHUAZX10's Avatar
Images: 7
Send a message via Yahoo to JOSHUAZX10
My 06 has a flasher under the seat next to the fuse box, I'm sure the 05 is relatively the same...
JOSHUAZX10 is offline
post #4 of 6 Old 05-04-2008, 12:23 PM Thread Starter
signals
do you no if it has a white plug with a orange an a brown wire i have one of those that is not plugged in to nothing
poboy is offline
post #5 of 6 Old 05-04-2008, 12:30 PM
JOSHUAZX10's Avatar
Images: 7
just looked at my 06 and it's the same, an orange wire and a brown wire with a yellow stripe...problem solved
post #6 of 6 Old 05-04-2008, 01:36 PM Thread Starter
thanks that was a great help perfect
poboy is offline
Turn signal fix for 08. Dino Pictures and Videos 21 04-28-2008 10:06 PM
WTB rt rear turn signal 06-07 & lft front turn signal zero lash Wanted: Buy or Trade 2 03-05-2008 08:33 AM
Turn signal mod? pieter3d The ZX-10R 27 12-03-2007 11:08 AM
Turn Signal? bcm0018 Performance and Tech 5 08-19-2007 11:55 AM
turn signal issue Supraman78 The ZX-10R 1 08-20-2006 10:59 AM
