>> Turn Signal Issue << - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By evallarta1
  • 1 Post By Porschenut
post #1 of 6 Old 10-11-2018, 05:57 AM Thread Starter
Melampus's Avatar
Question >> Turn Signal Issue <<
Gen 1
39,000 miles
So I got her off the track about a year ago, and have been piecing her back together for street duty. I recently installed euro-style front left & right flush mount turn signal indicators, and upon plugging them into their respective clips, they did not work. I traced their respective wires back into the wiring harness, and nothing looks cut nor visibly damaged. When I activate the actuator on the clip-on my dash will blink, but it is in a very quick series of flashes. That made me think that it was a resistance issue in the circuit as, it is of note, I do not have rear indicators installed as of yet. So then I put a multimeter to the front left & right plugs to check them, and there's no juice. Then I pulled the seat to check the fuses, and that 10 amp looks just fine.
So does anyone have any ideas as to what I can do now? I can't stand using hand signals, and most people don't understand them anyhow.
Embracing the silence amid a life & land full of static...
Melampus is offline
post #2 of 6 Old 10-11-2018, 09:38 AM
evallarta1's Avatar
Pretty normal problem. There are a bunch of solutions, but what I did for mine in the past was get a "fixed flasher relay" at a auto parts store. These dont care what load is on the circuit, the flash is controlled electronically. That way you can have 1 or 50 blinkers and nothing changes.
Good Luck.
Melampus likes this.
Velocity Calibrations
evallarta1 is offline
post #3 of 6 Old 10-11-2018, 11:43 AM Thread Starter
Melampus's Avatar
Question
VALLARTA <> Hello, and thank you for your input although I'm a bit confused. Are you suggesting that the OEM relay may have failed which is why my blinkers won't illuminate? If so, that would be a fantastically easy fix! I'm over here worrying about having to replace my entire wiring harness.
Melampus is offline
post #4 of 6 Old 10-11-2018, 01:02 PM
Porschenut's Avatar
I agree with Evil. It sounds to me like you need to swap out the OEM flasher relay with an electronic LED flasher relay. Something along these lines:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=led+flash er+relay+zx10r&_sacat=0&LH_TitleDesc=0&_osacat=0&_ odkw=led+flasher+relay&LH_TitleDesc=0
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #5 of 6 Old 10-12-2018, 12:03 AM Thread Starter
Melampus's Avatar
Thumbs up
PORSCHE <> Then so it will be! That's what I'll jump in to next time on the bike. Ordering now.
Thank you, both!
Melampus is offline
post #6 of 6 Old 11-07-2018, 09:27 AM Thread Starter
Melampus's Avatar
Thumbs up
That was it; THANK YOU!
I replaced the flasher relay, and problem's solved.
Melampus is offline
WTB 06 07 Engine / motor <<<<<<<<< NMBR1SPT Wanted: Buy or Trade 6 09-14-2013 06:55 PM
>>>>>2008 zx-10r - $6,300<<<<<< swing lo Bikes 4 Sale 12 07-14-2010 11:16 PM
Fellow ZX10 family... Need your support<<<<<<<<<<<< nbrion1 The Out House 25 01-22-2010 07:25 AM
