Turbo Questions? - Kawasaki ZX-10R.net
post #1 of 10 Old 10-28-2008, 11:42 PM Thread Starter
walkthisway21's Avatar
Turbo Questions?
K so i think this winter im gonna buy a turbo setup.Ive wanted one for a while and feel i have enough years of ridin under my belt and some money to buy one but i have a couple questions.
1. Is there anyway to conceal the air filter?
2. Can you still run some sort of slipon exhaust as the cops around here arent to friendly to open exhaust? How loud is a typical turbo setup
Any help would be appreciated!
Thanks a bunch
Mods: Full Arrow, Front Clear Signals, GPR Stabilizer, PCIII, Smoke Windscreen, Vortex Spools, Solo Cowl, Pazzo Levers, Homemade Undertail, Secondaries Removed, K&N Filter,-1+2,Wheelstripes,Powdercoated Rearsets/Pegs,White Gauges,HID'S,Alth Rotors,Steel Braided Lines, Nissin Radial Master,Lens Covers,Shortened Pipe
walkthisway21 is offline
post #2 of 10 Old 10-29-2008, 08:46 AM
Retired post whore
Alien10's Avatar
There are several members here that are very knowledgeable with turbos (Vince10r, hesaves, redline), maybe they will chime in and answer some of your questions.
Alien10 is offline
post #3 of 10 Old 10-29-2008, 08:56 AM
turboten's Avatar
Turbo is a little louder than a slip on but not louder than a d&d slipon exhaust. Because of the turbo being in the exhaust system. As far as a full exhaust system to quite it down im working on building a kit for the zx10 with a custom slip on since no manufacture is making one at this time.
Im working on concealing a filter as well i found one i just need to see if it will work on turbo im planning on using for the kit.
turboten is offline
post #4 of 10 Old 10-29-2008, 11:27 AM Thread Starter
Thanks for the help. Please keep me posted as this will probably be my winter project and still have lots of time lol.
post #5 of 10 Old 10-29-2008, 12:13 PM
kawi9's Avatar
The turbo keep around 30% of sound. You can run with short slip on. But with full system you will lose some power, if you compare with short straight open exhaust. I lose 10whp at 8psi with full system vs staight pipe, but it's less noise for daily ride and no problem with police. Check the link
https://zx-10r.net/forum/showthread.php?t=57449
You can buy a short K&N air filter for don't cut the fairing. I cut my K&N air filter for sleeper look.
ZX9R TURBO 00 : J.E. Forged Turbo Pistons, Ported Head, Cometic Head Gasket, Adjustable Cam Sprockets, Barnett Clutch, Intercooler, W/M Injection, 2 Stage Boost, Factory Pro Jet Kit, Dynatek Ignition....
kawi9 is offline
post #6 of 10 Old 10-29-2008, 12:43 PM
inappropriate
hesaves0211's Avatar
Images: 67
:iamwithst
also, the search button works great
as far as the air filter goes, your best bet for performance would likely be to just deal with it. having a smaller air filter may impact your turbo's spooling or hp output. but what ever you do run an air filter!
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #7 of 10 Old 10-30-2008, 07:23 PM
redline659's Avatar
Build your motor. Including a clutch basket!!!!!!!!!!!!
Get the biggest huffer you can fit
redline659 is offline
post #8 of 10 Old 10-30-2008, 10:04 PM
jblaze's Avatar
Images: 14
Can you run a turbo bike in the rain? Meaning, will it malfunction due to water getting into the air filter then the motor?
jblaze is offline
post #9 of 10 Old 10-30-2008, 10:10 PM
no different than the water getting in the ram air, through your filter and in your engine.
Don't see why you would run it in the rain though.
maineiac1008 is offline
post #10 of 10 Old 10-30-2008, 10:19 PM
kawi9's Avatar
It's not a problem, i push some water in my motor with my Water/Methanol system.
kawi9 is offline
turbo motor and turbo kit 04-05 dble r Parts, Gear and Accessories 13 09-28-2008 08:36 PM
turbo 04 zx-6rr vinnyzx-6rr Performance and Tech 4 01-09-2007 06:01 PM
muzzy turbo or velocity turbo turboten Performance and Tech 20 09-13-2006 10:47 AM
Turbo 10 41ants Performance and Tech 11 01-19-2006 09:38 AM
Suzuki Hayabusa Turbo vs. Dodge Viper GTS Twin-Turbo jb_motogp Pictures and Videos 0 08-03-2005 02:16 AM
