Turbo info please - Kawasaki ZX-10R.net
post #1 of 4 Old 07-18-2010, 02:11 PM Thread Starter
zx-sik-r's Avatar
Turbo info please
i have a guy with a 04 10 thats wants me to build him a turbo grudge bike.ive been told alot of things about setups,but i know there are a few guys on here that have nice setups.i know im gona have Ryan Kallina do the head for me,what size and brand turbo should we run?gona do pistons and rods,head studs for sure.id like to c the bike run 5.6x's in the 1/8.whats it take to accomplish this with a turbo?any info would be awesome
zx-sik-r is offline
post #2 of 4 Old 07-18-2010, 08:37 PM
dsabat's Avatar
5.60s is not a problem, you could do that with a 40 shot and arm extensions.
A Garrett (or Turbonetics, or Precision) 50 trim TO4E / T3 stage 3 turbine is a popular, tough, and relatively cheap turbo that will spool quickly and still be able to make 400hp. You can find one online for $600.
If he wants a street/strip turbo, a Garrett GT28R ball bearing is a good choice. Little pricier, limited to maybe 325hp, but will spool a little quicker.
But if it's just drag, stick with a journal bearing T3/T4 hybrid. The ball bearing turbos are more touchy, and the center sections can't be rebuilt. If you hurt it, it's done.
good luck,
Dean
dsabat is offline
post #3 of 4 Old 07-18-2010, 08:49 PM
redline659's Avatar
Like dean said but I am partial towards ballbearing turbos. They lite alot quicker and are more efficient. You can get the big 28's that flow over 400 but for a bike to run mid 5's that wont be needed. Make sure he understands how much its going to cost to build a turbo bike right the first time. There is alot to it where a shot of spray is cheap and easy. Also mid 5's isnt going to get you with a grudge bike to play with the big boys
redline659 is offline
post #4 of 4 Old 07-18-2010, 11:08 PM Thread Starter
zx-sik-r's Avatar
yeah i put my stock motor 10 into the 5.5x's easy,i know whow to build a 10 for spray and motor...thats no issue.im def gona build it right,im not the type to build anything"cheap".man grudge racing has all kinda meaning...you can grudge race pit bikes...i know the level it takes to run with the big boys...there isnt that caliber of drag bike around here so mid 5's is perfect.i guess from what i read the cheaper turbo will work great for what were shooting for.well prolly build the engine first throughout the year and then get the electronics and turbo after.is this bike gona need a lockup?i want the boost to be managable,the only way you make clean passes is to have a good setup.if i can bring the boost on strong about the 330 without alot of clutch slip id be happy.i run low 5.5x's on my personal bike with a 40 shot and it seems to be just fine with some spacers.i still have a ton of ?? about this build cause ive never worked with turbos but im very open to opinon and guidance on this.ill worry with the details when i get started.thanks for the info guys
zx-sik-r is offline
Attn turbo guys join the group "turbo-10r" hesaves0211 The Out House 4 02-11-2009 09:28 PM
info. on 04/05 turbo kit michboy Performance and Tech 2 12-18-2008 05:18 AM
muzzy turbo or velocity turbo turboten Performance and Tech 20 09-13-2006 10:47 AM
Info on turbo kit? maze The ZX-10R 14 11-04-2005 07:06 AM
Suzuki Hayabusa Turbo vs. Dodge Viper GTS Twin-Turbo jb_motogp Pictures and Videos 0 08-03-2005 02:16 AM
