Trying to remove front wheel...where to buy 14mm hex socket?! - Kawasaki ZX-10R.net
post #1 of 16 Old 09-01-2006, 07:50 PM Thread Starter
Send a message via AIM to cyclops24 Send a message via Yahoo to cyclops24
Trying to remove the front wheel. I read the posts on here and apparently the 04's must have come with a 14mm allen key in the tool kit but when I looked in mine tonight the 05 doesn't have one. I went to Sears, Lowes, Pep Boys, Napa and everywhere else I can think of. I found them online all over the place but is there anywhere I can go and buy one with having to order and wait for it? It seems like every time I do some home mechanic work I need a special tool that or weird size that is hard to find. I get to add to my nice tool collection but it is pissing me off now cause I was hoping to get my tires on tomorrow.
cyclops24 is offline
post #2 of 16 Old 09-01-2006, 08:12 PM
bluedevil's Avatar
you need at least for special tools a 14mm allen or 22mm socket to take the axle out. Keep the pinch nuts loose from whatever side you use to loosen, by the tool you have(14mm allen left side 22mm socket right side) but the pinch nuts on the forks still tight on the opposite end to keep that end from moving. After that take it out and your in the clear and of course reverse order.....so go buy a 22mm socket and take it out that way if need be....but be carefull the 14mm side is Aluminuim and can strip easy with the steel axle.
bluedevil is offline
post #3 of 16 Old 09-01-2006, 08:23 PM Thread Starter
I have the 22mm socket. According to the shop manual, it sounded like you needed to loosed the nut then take the axle out. Hmm...I am going to the garage and tightening the axle nut side and I will see if I can get it out. Thanks!
post #4 of 16 Old 09-01-2006, 08:23 PM
rocketracermike's Avatar
Thats what i did and i went out and bought bolts. now i just put a socket on those puppys.
rocketracermike is offline
post #5 of 16 Old 09-01-2006, 08:31 PM
Harbor freight has almost everything.
GT ZX10 is offline
post #6 of 16 Old 09-01-2006, 08:49 PM Thread Starter
Wheels are off! That was easy. Thanks bro!
post #7 of 16 Old 09-01-2006, 08:52 PM
bluedevil's Avatar
glad to help.
post #8 of 16 Old 09-01-2006, 09:27 PM
10roller's Avatar
yea easy huh.
just for future reference to make this easy.. if anbody else is wondering you dont need the 14 mm hex key. just leave that entire fork alone. get the 22mm socket and loosen and remove the axle after you loosen the 6mm hex bolts underneathe the bolt (right fork).
edit: yea what bluedevil said.
10roller is offline
post #9 of 16 Old 09-02-2006, 04:21 PM Thread Starter
Tires mounted and wheels put back on. Thanks for everyone's help that was easy. I am a little bummed I didn't realize there are new Pilot Powers, the 2CT. I got the regulars. Oh well, next time.
post #10 of 16 Old 09-02-2006, 08:07 PM
phastone's Avatar
Does anyone know where to get the 14 mm hex? Just in case someone wanted to follow the directions.
phastone is offline
Front Wheel SliverR6 Wanted: Buy or Trade 7 06-05-2006 09:09 PM
right or left to remove front sprocket nut? skypatcorbin Performance and Tech 2 05-17-2006 11:30 PM
front wheel Till_I_Die Wanted: Buy or Trade 0 03-18-2006 09:47 PM
Front wheel mickyboy The ZX-10R 13 06-28-2005 04:48 PM
to remove front axle clamp bolt kuzco The ZX-10R 10 04-01-2005 01:28 AM
