Gen 1: 2004-2005 TRE with or without sec flies removed - Kawasaki ZX-10R.net
post #1 of 19 Old 06-30-2012, 03:30 PM Thread Starter
zx racer's Avatar
hey guys just wondering is it ok to remove the sec flies with a TRE installed or is it best to leave them in... any feedback anybody can share will be appreciated.
05 ZX-10R SWB.
zx racer is offline
post #2 of 19 Old 06-30-2012, 03:38 PM
codyc_13's Avatar
I had them removed with a TRE on my 06.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 19 Old 06-30-2012, 04:03 PM
meanstreak5's Avatar
Still have a little restriction of flow with them in and the servo motor has to still open them up. The TRE just tricks the computer into thinking the bike is in 6th gear or 5th one cant remember. There is a soft and hard setting on the one I have (GI pro ATRE). I keep mine on the soft setting which has seemed to help with it being so jumpy when exiting a corner while rolling on the gas. I dont think you will get a noticeable change in performance with them out as opposed to being in with a TRE. I already had mine out when I installed the TRE.
2000 WR400 SM, 2004 KTM 300EXC, 2005 1800 Wing, 2006 ZX10R, 2017 ZX10R
meanstreak5 is offline
post #4 of 19 Old 06-30-2012, 04:11 PM
bluedevil's Avatar
TRE the Ivans one or home made tricks the ECU (Edit) thinks that it's stuck in Neutral gear so faster on off sub-throttle I believe....if your running a PCIII I would just remove the TRE unless your going to map with that alone.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #5 of 19 Old 06-30-2012, 04:15 PM
preybird1's Avatar
tre?
A 1st gen zx10 needs a custom map to run a TRE properly. The secondary butterflies can be removed in 20 minutes as long as you don't strip the screws out!! The TRE has nothing to do with the secondary flies or there operation.
preybird1 is offline
post #6 of 19 Old 06-30-2012, 04:23 PM
preybird1's Avatar
Info from ivans performance web page
2004 & 2005 Kawasaki ZX10R (requires special mapping)
(use TRE-006 - $60.00)
TRE-008 - $70.00
2006 - 2010 ZX-14
Increases power below 6000 rpm!
Does not disable speed limiter
Gets rid of part throttle timing retarder in lower gears.
Allows 6th gear (fastest rate in stock ECU) throttle plate opening rate.
TRE-006A - $60.00
2006 & up ZX-14
Requires sub-throttle plate removal & special mapping.
Gets rid of fuel shut-off on decell -
This will allow smooth on/off throttle transitions and will get rid of the annoying pop when the throttle is reapplied.
Our maps are only available with a minimum purchase of $200.00 or more.
TRE-009 - $60.00
2006 - 2010 ZX10R
Disables KIMS on 2008 - 2010 models
Increases part throttle response
post #7 of 19 Old 06-30-2012, 04:53 PM
bluedevil's Avatar
TRE-008 - $70.00
2006 - 2010 ZX-14
TRE-006A - $60.00
2006 & up ZX-14
TRE-009 - $60.00
2006 - 2010 ZX10R
This thread is about a 2004-2005 ZX10R your cut and Paste from Ivan's you see give NO INFORMATION only part # to order....no worry I already did the investigation among others on this site. Ivans is Neutral GEAR for ECU ONLY, he recommends messing with the sub-throttle sensor and MAP. Many have reported if done properly the on-off throttle abruptness is improved but most of them had Ivan's MAP.
bloo
post #8 of 19 Old 06-30-2012, 05:04 PM Thread Starter
zx racer's Avatar
hey cody was this with a pc or without.
i have them out now but just wondering if i should put them back in and if it would help with the low/mid range power. i thought the TRE on the gen1 tricks the ecu to thinking it was in neautral where it advance the timing some and has lil more aggressive map.
05 ZX-10R SWB.
zx racer is offline
post #9 of 19 Old 06-30-2012, 05:09 PM Thread Starter
zx racer's Avatar
bloo
thats exactly wat i was thinking it did bloo... i have the TRE installed but havent remap for it. think its worth having the bike remap ?
i read on some kawi's when you install the TRE it messes with the sec flies *i think it was on the zx14's* but may be wrong. bike runs good with the flies out and TRE fitted now.
05 ZX-10R SWB.
zx racer is offline
post #10 of 19 Old 06-30-2012, 05:34 PM
bluedevil's Avatar
2 thoughts here going back to basics, I am not an expert on what the ECU maps guys like Ivan have learned for their application what works for them or to sell. What I do know is each GEAR has an ECU mapping controls many things sub-throttle one of them or not in this case if you remove them. then when you Piggy back with a PCIII you add to that...see?
As far as remap It's hard to say your one if not the fastest guys drag racing on this site and active on this site SWB to date and still fast stretched a little.
I actually kept mine in (Secondaries) did some home made mapping but will be experiementing removing them now that I have a Data Logger and A/F gauge...plus the 1/4 mile times should help too in the future if I really mess something up(edit like my past times).
secondary flies removed oldkamikaze General Motorcycle Discussions 22 03-31-2010 02:54 PM
flies v tre krakers10r Performance and Tech 0 09-17-2009 01:36 PM
flies pravataracing Strip 1 08-30-2009 05:01 PM
flies or not to flies beenthere Performance and Tech 9 04-02-2007 12:05 AM
Flies Removed green slime Performance and Tech 6 09-20-2006 12:32 PM
