TRE-TPS adjustment, good or not? - Kawasaki ZX-10R.net
post #1 of 27 Old 05-23-2007, 03:05 AM Thread Starter
Infamous's Avatar
Hi Guys!
I'm installing a TRE shortly and would like to hear opinions about adjusting the TPS...
I would prefer if you had a similar setup i.e full system, filter, PC3 and TRE.
edit: TPS - sub throttle position sensor
//Thomas.
starting to warm up in sweden now, almost 55 degrees!
swedish meatball.
Black 2004 with full Yoshi, PC3, TRE, Oggy knobs, C/A smoked tail light and smoked euro front turn signals, servo eliminator, öhlins steering damper, kawwi DB screen. thinkin about the air horn...
Infamous is offline
post #2 of 27 Old 05-25-2007, 11:42 AM Thread Starter
Infamous's Avatar
swedish meatball.
Infamous is offline
post #3 of 27 Old 05-25-2007, 12:17 PM
Still here
ZX10Miami's Avatar
It has been debated alot here.
10speed swears it is fine without the adjustment.
I adjusted mine and never had a problem.
Use a map made for the tre or else you are wasting fuel at low rpms due to the adjustment.
The down side is that if you manage to damage the tps while adjusting it, you have to buy new throttlebodies @ $1200.00 give or take.
TPS not sold seperately.
ZX10Miami is offline
post #4 of 27 Old 05-27-2007, 11:20 AM Thread Starter
Infamous's Avatar
well, all done, so I'll just have to wait for the weather to clear...
swedish meatball.
Infamous is offline
post #5 of 27 Old 05-31-2007, 05:32 AM
inappropriate
hesaves0211's Avatar
Images: 67
ah good question glad i didnt waste my time. i got my air box and tank off right now. installed the tre, speedohealer and pc3. fortunatly i wasnt in a hurry to put it back together because i my apex torque bit didnt have the hole in the middle. also, im waiting on my bmc race and 1/5 throttle mod before i throw everything back together. the stock filter was dirty as hell!
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #6 of 27 Old 05-31-2007, 05:33 AM
inappropriate
Images: 67
can anyone else testify?
post #7 of 27 Old 05-31-2007, 10:02 AM
Post Whore
Sgtusmc96's Avatar
I adjusted mine and have had no problems in 2 years!
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #8 of 27 Old 05-31-2007, 10:53 AM Thread Starter
Infamous's Avatar
hopefully I'll be able to ride it sunday....
swedish meatball.
Infamous is offline
post #9 of 27 Old 05-31-2007, 10:59 AM
I did this mod to mine when I installed the TRE, and it works great =)
The throttle response will be much crispier - so watch out !
fordfasterr is offline
post #10 of 27 Old 05-31-2007, 11:31 AM
kneedragger's Avatar
What do you mean by the TPS? I just did the mod and I have a full system, K&N, PCIII, and yep just put the TRE in 2 weeks ago. Are you talking about the little throttle adjustment switch next to you left frame slider? I have had to play with mine a bunch sometimes when I go for a ride the bike will stall when coming to a stop with the clutch pulled in and the RPMs drop. I don't know why but I then will twist that little screw add more fuel and the bike idles around 1100 RPM. Is this what you are talking about?
I'm not fast I'm just faster than you
Bikes owned
97 ZX11, 98 R1, 00 CBR929, 02 RC51, 02 Duc 998, 02 GSXR 1000, 04 GSXR 600, 05 ZX10R, 05 ZX6R, 06 Husky TE 510, 07 ZX6R, 04 GSXR 750, 2001 CBR929RR, 2007 ZX10R SE Hows my resume
kneedragger is offline
1/5 throttle adjustment rojapar Performance and Tech 2 04-07-2007 10:26 PM
suspension adjustment help 10roller Performance and Tech 4 03-07-2007 07:13 PM
Valve adjustment done Tread70 Performance and Tech 24 10-18-2006 08:03 PM
throttle adjustment bradshow01 Performance and Tech 2 05-25-2006 05:31 PM
Throttle Adjustment? wycked10r The ZX-10R 4 09-19-2005 10:26 PM
