transmission woes - Kawasaki ZX-10R.net
post #1 of 26 Old 01-07-2005, 08:25 AM Thread Starter
BANNED
trikchop's Avatar
transmission woes
well i think ive finally fucked the transmission up in this bike. i noticed once last week. im in second and the bike jumps out and bak into gear real quick. i tried to tell myself that it was improper chain tension but last night i was riding and it happened a few times. im suprised it lasted this long. ive put this bike through some shit. poor thing
trikchop is offline
post #2 of 26 Old 01-07-2005, 09:17 AM
how the hell are you beating on it so bad...
MAVRIK is offline
post #3 of 26 Old 01-07-2005, 10:42 AM
MIA Post Whore
miykl's Avatar
I'll second that. What are yoiu doing with it that you consider it being beaten on?
miykl is offline
post #4 of 26 Old 01-07-2005, 10:50 AM
maze's Avatar
Look into the detent spring or the shift fork. My r6 broke its detent on a regular basis. the shift fork is more expensive. The mechanic told me that it kept breaking because the shift rod on the attack rear sets was shorter and put more force on the associated parts. I didn't buy it but I think it's possible.
The only thing nessecary for the triumph of evil is for good men to do nothing
"sometimes in order to truly live life you must risk it."
You hit the lights, I hit the gas...
THERE ARE ONLY THREE SPEEDS, FAST, VERY FAST, AND OH SHIT!
maze is offline
post #5 of 26 Old 01-07-2005, 11:43 AM
Jumping out of gear once fully engaged is usually due to worn gear dogs on the transmission cogs. Bent shift fork can help round off the gear dogs as it doesn't fully slide the gears together for full engagement.
If it's either of those, I assume you'll need to fully tear down the motor and split the cases (Not exactly sure with this new motor design) to remove the transmission shafts and shift forks.... Very labor intensive and expensive..... Just parts for my old yamaha 600 were ~$450, and it took a solid 10 hours with no problems to pull the motor, disassemble, re-assemble, and re-install in the bike.
Good luck.
Nuggy00 is offline
post #6 of 26 Old 01-07-2005, 11:50 AM
Shocker=another 600R with yamaha gearbox gremlins....I paid $1050 to have my tranny undercut and reinstalled with a factory pro shift kit, on the YZF600R. The yamaha transmission parts are a POS.
BNninja is offline
post #7 of 26 Old 01-07-2005, 01:33 PM
RF900 were know for blowing second gear...that wasn't cheap for my buddy
MAVRIK is offline
post #8 of 26 Old 01-07-2005, 01:52 PM
Actually in '00 a lot of GSXR750s had 2nd gear go...must be only Honda and Kawasaki that can build a decent tranny. Where are our 10/100,000mi power train warranties?
BNninja is offline
post #9 of 26 Old 01-07-2005, 02:14 PM
Alot of the D model ZX6's blew second also. Most of the time its the rider who doesn't shift with authority into second or in any gear for that matter. Gotta snap it into the next gear not just lift.
grnblur is offline
post #10 of 26 Old 01-07-2005, 02:16 PM
I should have said this earlier...the race shop that I go to told me to never use the clutch unless downshifting or coming from a stop, using the clutch allows you to screw up upshifts and destroy your tranny. Just an FYI.
As much as I want a Pazzo lever, I know that I never use the clutch, so I'm trying to be more sensible.
BNninja is offline
Suspension Woes livnpaintball Performance and Tech 73 11-09-2004 03:24 PM
Speedohealer woes Big Daddy The ZX-10R 13 06-29-2004 04:36 PM
BallMoto Undertail woes............ RUNNINHORN The ZX-10R 21 06-11-2004 11:31 PM
Painting woes......f#$%^@k Big Daddy The ZX-10R 18 05-14-2004 12:09 PM
