Transmission/ Clutch Gurus - Kawasaki ZX-10R.net
post #1 of 4 Old 09-24-2010, 09:05 PM Thread Starter
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
Red face Transmission/ Clutch Gurus
I've got a high pitched buzz/whine in 1st and 2nd @ 5-8 k RPM that disappears when I engage the clutch. Thenoise itself sounds similar to the ignition key buzz but a little higher in frequency. It dissapears at higher RPM in 1st and 2nd or alltogether in 3rd through 6th gears. I am guilty of missing a few shifts between 1st and 2nd at the track while hard on the throttle. Shift fork, dogs, any ideas. Am I mis-interpreting the noise and could this be something else? The thing that points me to the tranny is the fact that it quits when I pull the clutch. Can I continue to ride?
SUPER K is offline
post #2 of 4 Old 09-25-2010, 01:15 AM
bugman53's Avatar
Not normal and hard to fix over the internet with out having the bike here.
I would just take the clutch out and check bearing backlash and transmission shaft end play.
Has any work been done to the bike before the noise started? IE clutch changed?
bugman53 is offline
post #3 of 4 Old 09-25-2010, 12:37 PM Thread Starter
Chickenstrip Eater
SUPER K's Avatar
Motor and tranny are stock, and I haven't done any work short of fluid changes. No recent fluichanges or even maintenance work. It popped up half way through my last track day. Thanks for the reply, I've been thinking about a new clutch and this may be the excuse I need to get in there.
SUPER K is offline
post #4 of 4 Old 09-25-2010, 12:54 PM
tasos's Avatar
Better open the clutch up. Maybe clutch basket springs starting to go bad...
tasos is offline
Video of Dual Clutch Transmission (for motorcycles) Rspec99 Pictures and Videos 15 09-10-2009 04:33 PM
Photoshop gurus... need help Bigprfed22 Pictures and Videos 0 04-21-2008 09:42 AM
photoshop gurus! Mustard The Out House 11 07-11-2007 11:33 AM
05' Clutch/transmission problem? rocket10r Performance and Tech 14 03-19-2005 09:09 AM
HELP!! PCIII Gurus miykl Performance and Tech 12 08-31-2004 11:04 PM
