Gen 1: 2004-2005 Transmission clicking - Kawasaki ZX-10R.net
post #1 of 5 Old 08-28-2014, 08:30 PM Thread Starter
Exclamation Transmission clicking
My bike has about 40k miles on it and recently the front sprocket or transmission is making a clicking sound while im moving. It speeds up with the bike which makes me lean more towards the sprocket. But i have no idea what it is. The front sprocket is one tooth up from OEM if that helps. Also my valvetrain is a little noisy. Maybe cct? Ill post a video if any wants to see it
CAPTAIN_CAM_PANTS is offline
post #2 of 5 Old 08-29-2014, 02:20 AM
Driaannel's Avatar
How old is the chain? if the chain and sprocket is still in good condition maybe just needs some chain wax.
then again im new so might be talking out of my ass.
Driaannel is offline
post #3 of 5 Old 08-29-2014, 12:13 PM Thread Starter
Chain and both sprockets are maybe a year and a half old. I thought about that too so I did wax them but it comes back after a week or so.
post #4 of 5 Old 08-29-2014, 12:26 PM
SkyDork's Avatar
So the clicking goes away when you lube your chain? That tells me the chain is dry and the sound you're hearing is it smacking the swingarm guide. You should lubricate your chain every 3-400 miles.
The chain and sprockets wear together and get tight spots in the chain. As these tight spots run the top of the chain forward, it can bounce on the chain guide and cause an audible clicking noise. Sometimes you'll even feel it it in the left footpeg if it's bad enough. It should smooth out under heavy acceleration as the top chain run tightens. And it will get worse as you're slowing down.
Make sure your chain is properly adjusted and lubricated and see if the noise changes.
The CCT would sound totally different, would not be speed dependent, and would come from the right side of the motor if that were and issue. Doesn't sound like it to me.
#WordCrimes
SkyDork is offline
post #5 of 5 Old 08-29-2014, 04:47 PM Thread Starter
The transmission clicking is unrelated to the valve train noise. I just wanted to add it in there. It is coming from the right side mostly. I can hear it on both sides. It's not incredibly loud, it's just noticeable.
CCT not clicking shinde92 The ZX-10R 28 08-28-2013 07:30 PM
Gen 2: Clicking Noise tmzx10r The ZX-10R 11 05-19-2013 04:28 PM
Gen 2: Got a clicking sound KawieKrazy The ZX-10R 4 06-02-2011 10:18 AM
Forks clicking!!!! Superbike1 Performance and Tech 6 06-05-2006 11:25 PM
Whats the clicking?? Danezx10r The ZX-10R 9 07-07-2005 08:20 AM
