trackdays says water only in the cooling system(Radiator) - Kawasaki ZX-10R.net
post #1 of 23 Old 02-25-2008, 05:33 PM Thread Starter
limegreenbloodz's Avatar
Hi guys,I will start track days this year and I have no problem about what they are asking me to do on the bike except for one thing:you have to drain the antifreeze from the cooling system and fill with water only because they say it could leak and antifreeze is very slippery and can cause and accident.
so I was wondering if the engine will run hotter/with water only .
Is there any other liquid that can be used instead of antifreeze that won't be slippery??
limegreenbloodz is offline
post #2 of 23 Old 02-25-2008, 05:40 PM
hangman39's Avatar
Actually mine runs cooler on distilled water than it did with antifreeze in it.
hangman39 is offline
post #3 of 23 Old 02-25-2008, 05:44 PM
Big Daddy's Avatar
Images: 38
What the organizer is asking is semi common here in the US as its not only very slippery but in the event clean up is necessary its a nightmare.
Yes you can add Redline water wetter to the plain water as it helps keep the pump lubed and reduces overall heat.
http://www.redlineoil.com/products_coolant.asp
Big Daddy is offline
post #4 of 23 Old 02-25-2008, 05:48 PM
Big Daddy's Avatar
Images: 38
very true as plain ol water is superior when it comes to managing heat disipation.
post #5 of 23 Old 02-25-2008, 05:49 PM
Rspec99's Avatar
Images: 11
Antifreeze is exactly that. It lowers the freezing temperature, but it doesn't improve the thermal efficiency of your cooling system. If you're looking for the best cooling, use distilled water and a few cap-fulls of water wetter.
Some track's allow the use of Engine Ice, http://www.engineice.cc/
I have not used this myself.
Rspec99 is offline
post #6 of 23 Old 02-25-2008, 06:12 PM
ninja44's Avatar
I used distilled water and water wetter in the summer and my 06 never went above 91 Celsius in stop and go traffic, once moving on the highway it dropped 10 degrees to about 70. Just make sure you run the bike with the cap off to "burp" the system well. It shouldn't take you any more than 45 mins TOPS!
________
EXTREME VAPORIZER
ninja44 is offline
post #7 of 23 Old 02-25-2008, 06:30 PM Thread Starter
thanks there this really help.going to buy a bottle of Water Wetter tomorrow.
does this mean I could run with distilled water+Water wetter all the time(on the Track and on the road)
post #8 of 23 Old 02-25-2008, 06:34 PM
hangman39's Avatar
Except when it is cold enough to freeze I run just distilled water year around
post #9 of 23 Old 02-25-2008, 07:23 PM
ducatiryder89's Avatar
Images: 21
So 91 minus 10 equals 70 now? But you are right. Remember to "Burp" the system. Depending on the climate you live in you could run Water with Water wetter all year round. I wouldn't anywhere temps drop anywhere near 45 degrees F. But make sure you run the water wetter because water doesn't have the lubricating properties requiered by the water pump and so forth.
ducatiryder89 is offline
post #10 of 23 Old 02-25-2008, 07:31 PM
hangman39's Avatar
You also might want to check with the trackday organization that you are going to do trackdays with some do not even allow water wetter.
Flush radiator and add water--preparation for trackday Musikkant54 Race and Stunt 13 10-11-2007 01:17 PM
Muzzy radiator fan and water wetter glockt Performance and Tech 2 04-24-2007 08:08 AM
Cooling system Capacity truebudo Performance and Tech 1 09-29-2006 05:20 PM
Radiator cooling fan GreenGoblin Wanted: Buy or Trade 4 08-18-2006 12:27 AM
Purging the cooling system... Older Guy The ZX-10R 4 05-28-2006 06:41 PM
