TPS sensor bad???? - Kawasaki ZX-10R.net
post #1 of 3 Old 05-18-2011, 01:28 PM Thread Starter
redline659's Avatar
TPS sensor bad????
Question,
I seem to have run into an issue with my TPS. Everything specs out as far as resistance on the TPS, voltage going to TPS, and ground. However the TPS will not return any voltage on the signal wire. Anyone run into an issue like this?
redline659 is offline
post #2 of 3 Old 05-18-2011, 07:27 PM
ducatiryder89's Avatar
Images: 21
Checking main or subthrottle sensor? Also are you checking at ECU? Silly questions but its a start.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #3 of 3 Old 05-18-2011, 11:23 PM Thread Starter
redline659's Avatar
Figured it out. Had the signal wire grounded out in a tight spot.
Gen3: Throttle position sensor, and Crank sensor, where are they? (bazzaz related) Dr.Duct_Mossburg The ZX-10R 2 05-15-2011 07:16 PM
O2 sensor 2BIGFRED The ZX-10R 9 06-16-2010 06:36 AM
Tip over sensor UP10 Performance and Tech 2 06-13-2010 07:23 PM
TIP OVER sensor? Ninja187 Performance and Tech 8 06-26-2008 11:20 PM
Tip Over Sensor ( Vehicle Down Sensor) Papo-T Performance and Tech 1 06-02-2008 07:12 AM
