Torque wrench question - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SpazOnaZX
post #1 of 9 Old 05-02-2015, 11:19 PM Thread Starter
serialize's Avatar
Hello. Sorry if this is an obvious and stupid question.
I searched around Google and what not, either didn't understsnd or find what I was looking for.
I would like to know, when I use the torque wrench and I need to get into a tight spot and add a 6" socket extention (not at the end of the bar for leverage, just a socket extention at the driver end to get into a tight spot); do I need to use the torque multiplier calculation?
Thanks in advance for any help and feedback.
serialize is offline
post #2 of 9 Old 05-03-2015, 12:10 AM
Bottoms-Up's Avatar
Honestly I never really thought about it much and I always torque everything.
But... easy enough to test.
Torque a bolt down with an extension and then take off extension and
torque again to see and could do it the other way too as a second test.
My guess is it doesn't matter the direction of the torque is the same, side to side.
Bottoms-Up is offline
post #3 of 9 Old 05-03-2015, 03:18 AM
SkyDork's Avatar
No. You're applying a mechanical advantage to the wrench, but the torque is still being measured by the wrench the same way.
#WordCrimes
SkyDork is offline
post #4 of 9 Old 05-03-2015, 07:08 AM Thread Starter
serialize's Avatar
Thanks for the replies guys.
So I guess the calculation for angle extensions and what not.
post #5 of 9 Old 05-03-2015, 11:55 AM
SpazOnaZX's Avatar
So long as you don't "bounce" the torque wrench you can use any size extension you like. A good trick is slowly pull the wrench to torque and hold at the click/break for a few seconds. That keeps you from "bouncing" to the torque number and letting the extension act like a spring. Force applied to one end will equal the same force at the other end so long as the tension is in equilibrium. :)
Now if you used something to extend the -length- of a torque wrench you're going to have to do some math. :)
SpazOnaZX is offline
post #6 of 9 Old 05-03-2015, 12:08 PM
SkyDork's Avatar
But that's exactly what he's referring to. Adding a cheater bar to the end of the wrench to lengthen it, not a socket extension.
And there should be no math involved as the click/break is based on the measured torque at the head of the wrench. Just because there's a cheater bar on the end of the wrench doesn't change the torque applied when the wrench hits the break point. It just means that the torque wrench will be easier to turn up to that point. What you feel at the wrench will change with the length, but not the torque applied at the bolt.
#WordCrimes
SkyDork is offline
post #7 of 9 Old 05-03-2015, 03:27 PM
SpazOnaZX's Avatar
...and as far as extending the length goes, I was talking about using a crows foot or some other type of lateral extension from the socket head.
SkyDork likes this.
post #8 of 9 Old 05-03-2015, 03:32 PM
SkyDork's Avatar
Man, I suck. Totally misread the issue.
Yes, a crows foot type extension on the end is not accurate like you said. And just a socket extension won't change the torque either. So ignore my posts above and just read Spaz's.
#WordCrimes
SkyDork is offline
post #9 of 9 Old 05-03-2015, 09:44 PM Thread Starter
serialize's Avatar
Thanks again guys.
Yeah I'm good, no math needed was just using a simple socket extention to get into a narrow spot.
For Sale: Matco trb75f torque wrench TINYTURBO Garage Sale 4 08-23-2012 11:38 AM
Torque wrench Hemiap Performance and Tech 18 12-24-2011 02:54 AM
89in-lbs = 7.4 ftlbs on torque wrench ??? xx8055NIACxx Performance and Tech 12 04-06-2009 05:34 PM
What kind of torque wrench to buy??? kneedragger_13 Performance and Tech 25 04-18-2006 12:55 AM
Good Torque Wrench? zx10ragentblack Performance and Tech 15 10-18-2004 10:52 PM
