torque specs? - Kawasaki ZX-10R.net
post #1 of 11 Old 08-06-2007, 03:29 PM Thread Starter
torque specs?
To ignorant to buy a real manual yet...... Anybody know the torque values for the triple clamp pinch bolts and clip on pinch bolts? Lowering the front 4-6mm and was hoping one of you guys would help me out THANKS MUCH!!! Oh yeah its an 07' zx10. response appreciated !!
gsxrmitch is offline
post #2 of 11 Old 08-06-2007, 03:30 PM
dsabat's Avatar
Gutentite :)
I admit that I don't look up torque values for anything other than rod, case and cylinder head bolts.
I would guess 20lbs for a 10mm bolt is safe.
dsabat is offline
post #3 of 11 Old 08-06-2007, 03:40 PM
Big Daddy's Avatar
Images: 38
04,5 specs for upper pinch bolts 14.5ftlbs
specs for lower " " 22ftlbs
clip-on pinch bolts 18ftlbs
Big Daddy is offline
post #4 of 11 Old 08-06-2007, 03:47 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Until it stops?
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #5 of 11 Old 08-06-2007, 03:57 PM
Pressley10r's Avatar
Send a message via AIM to Pressley10r
Originally Posted by SalKhan View Post
Until it stops?
+1 thighten the piss out of it, id tighten them as tight as you can with the allen; you definitely wouldnt want them to come loose!
BIKES ARE THE FASTEST
Pressley10r is offline
post #6 of 11 Old 08-06-2007, 06:16 PM
05Ti10's Avatar
I hope your joking. Things have torque specs for reason. Buy a torque wrench and do it right. Doing what you say, is how things get stripped and rounded off if done repeatedly. It does not take much torque for those clamps to hold on to the tubes.
Steve
05Ti10 is offline
post #7 of 11 Old 08-06-2007, 06:54 PM
SalKhan's Avatar
Clamping forces are certainly stronger than you would think. But if you don't have a torque wrench, you can alternate tightening until their both snug, and then give them another 1/4-to-1/2 turn.
You can certainly crush things as well, if you're not careful.
Sal Khan
SalKhan is offline
post #8 of 11 Old 08-07-2007, 07:05 PM
CFH
torqs
there is a manual for download @ this site .. and dont listen to the jackass that said to tighten the piss out of `em.
CFH is offline
post #9 of 11 Old 08-07-2007, 08:34 PM
06 zx10r
upper 15 lower 22 ft lbs clip-on 18 ft lbs
j_blevins75 is offline
post #10 of 11 Old 08-08-2007, 08:40 AM
lemme guess...you ride an 06-07 bike right?
torque specs ninja2k5 Performance and Tech 1 02-24-2007 11:55 AM
need help with torque specs fumes The ZX-10R 3 11-12-2006 01:44 PM
torque specs ninja2k5 The ZX-10R 4 05-10-2006 05:38 PM
torque specs please avdigigeek Performance and Tech 5 05-08-2006 06:38 PM
torque specs STREETFIGHTER50 Performance and Tech 2 09-18-2004 08:39 AM
