torque spec question... - Kawasaki ZX-10R.net
post #1 of 11 Old 01-15-2010, 07:58 AM Thread Starter
can anyone tell me what the torque spec is for the exhaust header studs is? it is not in the kawi service manual that i can find. i know the stud nut torque spec is 13ft-lb. any help would be great. thanks
cj
general01 is offline
post #2 of 11 Old 01-15-2010, 08:59 AM
meanstreak5's Avatar
I see what your saying, I searched the manual and couldn't find a torque speck for the studs either. If it were me I would use some high temp Loctight and put about 10 to 13 lbs on them. I would say Garth would have the right answer.
meanstreak5 is offline
post #3 of 11 Old 01-15-2010, 09:10 AM
Speed Freak
garth285's Avatar
ummmm quarter past snug :-p hahahha....
garth285 is offline
post #4 of 11 Old 01-15-2010, 09:11 AM
Speed Freak
garth285's Avatar
Its going to get tightened more when you go to put the nut on so I'd say just really give it a good snug and it will be fine.
garth285 is offline
post #5 of 11 Old 01-15-2010, 11:40 AM
Thats what I have always done on exhaust studs on autos and figured you cant go wrong by tightening them slightly less that the nut. From reading your posts I thought you prolly replaced your fair share of them.
post #6 of 11 Old 01-15-2010, 11:43 AM
Speed Freak
garth285's Avatar
yeah, I havent had to do a ton on the 10r's just had to steal one from another head of mine for the 06 head I put on my bike....
garth285 is offline
post #7 of 11 Old 01-15-2010, 12:52 PM Thread Starter
i have done quite a few on cars, but not on the ten. i would not normally care to much, but the turbo is going to be hanging off the studs, and that is a ton more weight than the normal exhaust, i though it should be on the tight side. i guess i will go with a few lbs more than the nut specs. thanks guys
post #8 of 11 Old 01-15-2010, 12:54 PM
Speed Freak
garth285's Avatar
yeah, are you running studs or bolts into the head??? they can only go so far before bottoming out so just check your measurements.
garth285 is offline
post #9 of 11 Old 01-15-2010, 03:52 PM Thread Starter
no, i just replaced the studs with longer ones so they would clear the bracket.
post #10 of 11 Old 01-15-2010, 03:53 PM
Speed Freak
garth285's Avatar
oh got ya, I think you'll be alright.
garth285 is offline
I need a torque spec please Titan10r Performance and Tech 6 03-07-2008 04:11 PM
Torque Spec help sewman Performance and Tech 2 11-13-2006 06:14 PM
Need Torque spec ZX10pilot The ZX-10R 3 09-20-2006 05:32 PM
Quick help please need torque spec... ZX-Dan The ZX-10R 3 05-17-2006 04:45 PM
torque spec?? williaj Performance and Tech 4 10-06-2005 01:30 PM
