Torque spec needed - Kawasaki ZX-10R.net
post #1 of 7 Old 03-21-2005, 08:35 PM Thread Starter
Torque spec needed
Dose anybody know what the proper torque spec in foot lbs is for the 36mm steering head nut.
mad-kaw is offline
post #2 of 7 Old 03-21-2005, 08:40 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
58 ft/lbs for the Steering Stem Head Nut
GuitarPlyr is offline
post #3 of 7 Old 03-21-2005, 09:19 PM
Post Whore
El Diablo's Avatar
Yep, what he said...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #4 of 7 Old 03-21-2005, 09:22 PM
Post Whore
Older Guy's Avatar
I torqued it tighteren a MoFo as that was the way it was when I tried to break 'er loose!!!
Older Guy is offline
post #5 of 7 Old 03-22-2005, 07:48 AM
That Is Not The Correct Way...your Actually Bending The Top Triple Clamp By Doing That
MAVRIK is offline
post #6 of 7 Old 03-22-2005, 07:49 AM
Make Sure To Loosen The Pinch Bolts On The Forks Before Any Adjustment Is Done
MAVRIK is offline
post #7 of 7 Old 03-22-2005, 02:01 PM Thread Starter
Thanks for the info.
mad-kaw is offline
New Supersport Spec ZX10 Dyno runs..185hp!!!! Rob Hughes The ZX-10R 38 10-17-2005 02:07 PM
HP vs. TORQUE Louks03 Performance and Tech 3 02-06-2005 05:13 AM
stearing head torque spec??? avdigigeek The ZX-10R 33 01-30-2005 01:57 PM
Effect of changing sprokets on torque graph CentBiker Performance and Tech 7 11-24-2004 09:19 AM
Torque spec 4 steering stem nut? HPower Performance and Tech 19 11-16-2004 08:28 AM
