??? for top speed racers - Kawasaki ZX-10R.net
post #1 of 33 Old 04-18-2008, 11:13 PM Thread Starter
Vince10R's Avatar
At what true top speed mph would an 05 zx-10 with 16,41 gearing without a speedo healer hit the factory restrictor(186mph). How does the bike kill the power after reaching the set speed? does it get its signal to kill from the speedo?
Vince10R is offline
post #2 of 33 Old 04-18-2008, 11:57 PM
bkkninja's Avatar
set by RPM. U hit the limiter at max RPM. hence top speed is at max RPM. Limiter kills engine.6th gear + 13,000RPM = Limiter cut.
BKK
bkkninja is offline
post #3 of 33 Old 04-19-2008, 08:51 AM
10 speed's Avatar
it pulls timing out. Ivas TRE resolves that.
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
post #4 of 33 Old 04-19-2008, 09:02 AM
Speed Freak
garth285's Avatar
that might work on gsxr's and busa's but not on zx10's
the bike is limited by RPM's if you want to go faster on top end yuo can either bump the rev limiter upeither with the KIT ECU or a ignition module from power commander.
with 16, 41 with a 190/55 tire it should probably be in the 170-172ish range
garth285 is offline
post #5 of 33 Old 04-19-2008, 09:13 AM
10 speed's Avatar
5th gear is not limmited and the TRE makes the bike think its in 5th at all times.
10 speed is offline
post #6 of 33 Old 04-19-2008, 09:38 AM
Speed Freak
garth285's Avatar
5th gear IS limited..... other wise everyone would blow up their bikes by over revving them. The 10r's are limited by RPM. my bike stock geared will do 186 on the REV LIMITER and I have been mid 190's on the limiter as well.....
My data logger has also showed the rev limiter cutting in in 6th gear at the same RPM as every other gear.
garth285 is offline
post #7 of 33 Old 04-19-2008, 10:31 AM
dsabat's Avatar
dsabat is offline
post #8 of 33 Old 04-19-2008, 10:42 AM
ibescott's Avatar
Send a message via AIM to ibescott Send a message via Yahoo to ibescott
Originally Posted by dsabat View Post
according to that it is about 175, close to what garth said
https://www.facebook.com/scott.d.barraclough
2005 PBO ZX10
2002 Blue Honda Goldwing
Sold 2004 Blue ZX10
Sold 2006 Blue ZX14
ibescott is offline
post #9 of 33 Old 04-19-2008, 10:54 AM
Speed Freak
garth285's Avatar
Yeah generally a front sprocket tooth will do +/- 9mph and a rear sprocket tooth will do +/- 4mph......
garth285 is offline
post #10 of 33 Old 04-19-2008, 10:55 AM
Speed Freak
garth285's Avatar
I think someone on the forums did a top end end run with a gps or radar gun but with a -1 up front they were doing 179mph
garth285 is offline
Some questions for the racers out there greenman43 Performance and Tech 3 01-22-2008 05:15 AM
Racers HELP!!! ZX10Rracer Race and Stunt 14 05-25-2007 10:48 PM
where are my drag racers Eleanor82 Strip 26 05-15-2007 09:30 AM
Drag racers! 1killer1liter Strip 45 10-28-2006 11:34 AM
Question for High Speed Racers Dave Bogue Race and Stunt 9 08-07-2006 03:49 PM
