Gen 2: 2006-2007 Top End Power Loss - Kawasaki ZX-10R.net
post #1 of 5 Old 08-06-2014, 12:56 PM Thread Starter
Top End Power Loss
Just picked up an 07 all stock except dual Yoshi bolt-ons. It is very weak in the upper rpms. From 8-9k rpms and up it's flat (bogs) It will keep reving to redline just not much power. From 1k to 8k rpms it runs good and starts easy. No fi or any other lights.
I checked the basics, plugs, air filter, all 4 cylinders seem to be firing by feeling the header and the exhaust valve looks like it's working. Also no power commander and its been down before but doesn't look like it was too hard.
Anyone else have a similar issue or know of some other things to check?
Thanks!
kawdawg is offline
post #2 of 5 Old 08-06-2014, 01:46 PM
SkyDork's Avatar
Fuel pump output pressure is typically the cause of poor running in the upper rev range.
Sent from Motorcycle.com App
#WordCrimes
SkyDork is offline
post #3 of 5 Old 08-06-2014, 02:27 PM Thread Starter
Thanks man your on top of things! Think I'll try my 05 pump for testing. Do you know if any of the aftermarket pumps are any good?
kawdawg is offline
post #4 of 5 Old 08-06-2014, 03:34 PM
SkyDork's Avatar
I've heard the Walbro ones are pretty good, but have no experience with them.
#WordCrimes
SkyDork is offline
post #5 of 5 Old 08-07-2014, 07:21 AM Thread Starter
Ok cool, yea I just saw a Walbro mod post. I'll check it out. Thanks again!
kawdawg is offline
Gen 3: 08 loss in power apollo240 The ZX-10R 5 09-17-2012 09:40 AM
Gen 1: Gen 1 : help!! Lost of power at top end vlRuS Performance and Tech 18 07-24-2011 06:58 PM
Bottom End Loss? ZX10_Ryan Performance and Tech 5 02-26-2010 05:01 AM
loss of power at 9k and above 10 nw ga. The ZX-10R 8 02-28-2009 10:07 PM
07' Loss of power 10RNOOB Performance and Tech 34 06-16-2008 07:07 PM
