Took the head out, take a look inside - Kawasaki ZX-10R.net
post #1 of 30 Old 08-23-2006, 07:27 PM Thread Starter
I am in the process of installing the thin gasket, cam, degreeing and some porting, and I saw a scratch along the combustion chambers. Is this a critical spot, it seems to me it is? How would this affect performance? I did not notice any problems before disassembling. Suggestion would be well received.
Boricua is offline
post #2 of 30 Old 08-23-2006, 10:06 PM
RIKKITIK's Avatar
The head on my bike had the same "scratched" surface finish, without the deeper scratches in your pictures. One of your pictures almost looks like combustion gasses were getting past the fire ring on the deeper scratch. If you can catch your fingernail on the deeper scratches, it might be worth looking into a cleen up cut on the head.
RIKKITIK is offline
post #3 of 30 Old 08-23-2006, 10:21 PM
mill the head and it will clean up all the surface scratches if your concerned.
deezuhl is offline
post #4 of 30 Old 08-26-2006, 09:44 AM Thread Starter
After more dissasembling look what I found. On the intake valves 4 valve retainers were broken in pieces. Have anybody had this happen? What could have caused it?
Boricua is offline
post #5 of 30 Old 08-26-2006, 10:18 AM
HOLY SHIT!!!!!!!!! Count yourself lucky to find that shit! How many miles are on those parts. And do you regularly bump the limiter ?
If I had my haed back off at this time I would angle mill the head and use the stock gasket. The angle milling will give you more piston to valve clearance and allow you to advance the intake to numbers impossible otherwise. Take enough off to allow you the margin to smooth up the chambers around the valves.
Gunner is offline
post #6 of 30 Old 08-26-2006, 12:54 PM
RIKKITIK's Avatar
It looks to me like the cam buckets were contacting the spring retainers (wear pattern showing on retainers). Correct adjustment shims should not allow this contact. When and who did the last vavle adjustment?
RIKKITIK is offline
post #7 of 30 Old 08-26-2006, 03:30 PM
Dragone's Avatar
Images: 11
ouch, and all this was on the intake side it seems.
Dragone is offline
post #8 of 30 Old 08-26-2006, 04:10 PM
have you ever had the valves adjusted?? if so they used the wrong valve shims.
FATTKAW is offline
post #9 of 30 Old 08-26-2006, 05:51 PM
After looking at this closer it appears that your bike had spit the shims out of their pockets and they got out of position between the bucket and retainer, Notice how the broken area is about the size of the shim Dia. Again you were lucky. But if that was the case there's probably more damage hiding there as well. In that reguard you're probably NOT going to be lucky again.
Gunner is offline
post #10 of 30 Old 08-26-2006, 10:20 PM
RIKKITIK's Avatar
Good eye Gunner. I'm kinda surprised that on the valve retainers showing damage, none of the locks came loose.
RIKKITIK is offline
Head to head my 10 & 05 Gixxer 1000 ZXTOM The Out House 28 05-12-2006 11:37 PM
Inside a tornado. sabersaw30 Pictures and Videos 3 06-24-2005 04:55 PM
I got 'er!!! Pics inside>>> El Diablo The ZX-10R 37 10-18-2004 07:31 PM
First competitive head-to-head? Zed The ZX-10R 8 03-05-2004 03:19 AM
Inside Scoop trkstarr The ZX-10R 12 02-03-2004 07:50 PM
