Gen 4: 2011-2015 Titanium Conrods - Kawasaki ZX-10R.net
post #1 of 6 Old 11-18-2014, 05:04 PM Thread Starter
abadassbikerlad's Avatar
Send a message via MSN to abadassbikerlad
Titanium Conrods
Hi thinking of going down the turbo route, and was wondering who makes Titanium con rods for this bike ?
2013 black uk spec gen 4, full akrapovic evo carbon, brembo rcs master cylinder, brembo clutch, ohlins race SCU, woolichracing flashed ecu with stock 02 disabled, ohlins mechatronic rear shock, Suoer corsa Sc2 200 rear smoked hot bodies rear end, Puig screen, s-2 concepts seat hump,Hell hoses, brembo m4 monoblocks samco sport red hoses, samco clamps, evotech oil cap, MWR filter, Putoline syntec 4, Jmt lion battery, nearly all bolts are titanium. 55w 6000k 2.5" Hid projectors.
190.26 hp Din
abadassbikerlad is offline
post #2 of 6 Old 11-18-2014, 05:46 PM
Ti rods would be a HUGE waste of money for a turbo build. When building a turbo motor think STRONG not necessarily light... Although light is never a bad thing it's just not necessary for a turbo set up where the blower can easily make you more power than you can use at any point in time.
That said Titanium rods are made by many different companies ranging from $2700 for a set to $2500 PER ROD for Pankl. I know because I've been shopping for them for my aspirated build where light mean everything. But I can tell you beyond any doubt if I were thinking turbo I would go steel with heavy tool steel pins and ring lands that are as lowered as you can get. Keep the compression at at least 10 to 1 for good off boost throttle response and keep the boost to or 8 pounds where pump fuel can be used unless it's a strict race bike then more compression and alcohol for fuel. This makes an intercooler un necessary and keeps detonation a word you don't become best friends with.
Gunner is offline
post #3 of 6 Old 11-18-2014, 05:46 PM
thundercoupe9's Avatar
Is there a reason you're considering titanium con rods vs steel alloy con rods that can support 500+ hp?
thundercoupe9 is offline
post #4 of 6 Old 11-19-2014, 12:06 AM
BigJay's Avatar
Surprising how many people thing titanium is stronger than steel.
Speed Merchant
http://www.zxzone.com
BigJay is offline
post #5 of 6 Old 11-19-2014, 01:46 AM
Being a welder and machinist most my life I've worked with just about every alloy including non metalic alloys like beryllium. Titanium is a tough alloy and nothing is stronger than steel alloys.
Gunner is offline
post #6 of 6 Old 11-19-2014, 03:31 PM
tyler.nd@hotmail.com's Avatar
I also think you have to watch the life span on Ti rods some companies say life span is much shorter then steel rods and don't like heat in turbo built compared to steel
05 Titanium 10 kwackattack Bikes 4 Sale 0 01-21-2009 10:28 PM
FS:Akrapovic Evolution 4/2/2 Titanium/Titanium Complete Exhaust W/ Hexagonal Mufflers ken98st Parts, Gear and Accessories 10 07-04-2008 01:31 AM
Titanium 10 x-factor Pictures and Videos 3 11-20-2006 03:35 PM
Titanium 06 zx10x2 Pictures and Videos 4 11-20-2006 10:14 AM
Almost new Muzzy titanium/titanium slip-on zx10r hc_performance Parts, Gear and Accessories 6 08-05-2004 11:02 AM
