Tires Dunlop GPA pros - Kawasaki ZX-10R.net
 3Likes
post #1 of 26 Old 12-26-2018, 09:42 PM Thread Starter
Lkeyzer's Avatar
Ordering soon , what do you guys think of these tires. Track use only.
Lkeyzer is offline
post #2 of 26 Old 12-26-2018, 09:55 PM
evallarta1's Avatar
Like any manufacture of tire you have pros and cons. Had to learn them pretty quick while working at K-Tech for MotoAmerica.
Not a bad tire, kind of a set and forget as far as pressures. Generally you can set them in the morning and leave them.
They do NOT like the cold.
Make sure they are heat soaked before you go out (minimum of an hour on the warmers)
Fronts wear like iron.
Check your manufacture date. 2018+ are very different from 2017 and before.
Velocity Calibrations
evallarta1 is offline
post #3 of 26 Old 12-27-2018, 05:45 AM Thread Starter
Lkeyzer's Avatar
Good info thanks. Yes I use warmers
Lkeyzer is offline
post #4 of 26 Old 12-27-2018, 10:21 AM
GreenWeenie's Avatar
I like them a lot, except for the 190/60 profile I prefer the 200/55. Ive used them on the track, and on the street. They are an OK street tire once they warm up.
Tire Warmers required for track use.
I have switched to the Slicks now. Comparable in price and last longer.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #5 of 26 Old 12-27-2018, 08:10 PM
mattinrsm's Avatar
I like the Dunlop’s, and have run them for years. If you aren’t racing or running in “A” group, you are better served with the Q4. I’d also recommend the slicks if you have a choice.
mattinrsm is offline
post #6 of 26 Old 12-28-2018, 12:52 PM
Q4s only lasted one day for me. Id say Q4s are good for smaller bikes, or slower B- paces.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
post #7 of 26 Old 12-28-2018, 05:59 PM
The Prophet's Avatar
Definitely slicks last longer. Good tires for sure. I recommend running a soft front(2262 as I recall) and a med, med + for the rear. You will never wear out a med front in the time it takes to wear out one or two rears. Definitely make sure they are up to temp before you lay the hammer down. I had a scarey front slide when my front tire warmer did not heat up. Not fun.
The Prophet is offline
post #8 of 26 Old 12-28-2018, 06:29 PM
nakedinseattle's Avatar
30/20 f/r, hour on warmers, hit t1 at full tilt, stiff carcass, like riding on a train rail around a corner, dunlops have been my favorite tire for ten years
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #9 of 26 Old 12-31-2018, 11:22 AM Thread Starter
Lkeyzer's Avatar
A group yes. I haven’t ordered yet , but haven’t ruled out slicks info I’m interested as well.
Lkeyzer is offline
post #10 of 26 Old 12-31-2018, 11:35 AM Thread Starter
Lkeyzer's Avatar
Ok, now I’m sold on slicks. Profile ? And is there a specific Dunlop slick . Haven’t looked yet myself.
Lkeyzer is offline
Dunlop GPA Tires toppz462 The ZX-10R 4 05-22-2014 02:17 PM
NEW Dunlop 209 GPA AMA Daytona Sportbike spec tires nikk777 Parts, Gear and Accessories 116 01-04-2011 10:16 AM
FS: Dunlop 208 GPA's & KR106 Racing Slicks mikdivad Parts, Gear and Accessories 2 08-28-2005 10:16 PM
Running Dunlop 208 gpa's on ZX10r realestateguy The ZX-10R 24 10-27-2004 09:45 AM
