Tires Dunlop GPA pros - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 26 Old 12-31-2018, 12:50 PM Thread Starter
Lkeyzer's Avatar
These?
Lkeyzer is offline
post #12 of 26 Old 12-31-2018, 08:44 PM
Originally Posted by Lkeyzer View Post
These?
Yep, I run the 190/55 on my 636 and the 200/55 on the Zx10. I would suggest the soft front(2262 I think it is) and the Medium rear. Go with recommended pressures and work down from there if you feel you need more grip.
The Prophet is offline
post #13 of 26 Old 01-01-2019, 07:55 AM
mattinrsm's Avatar
Dunlop isn’t making the 190 slick anymore according to their website. They are selling a 200/55 and a 200/60 which is new and specific they say for liter bikes. I haven’t run the 200/60 yet, only the 200/55. The new 200 is about the same diameter as the Pirelli and Michelin 200.
mattinrsm is offline
post #14 of 26 Old 01-01-2019, 04:43 PM Thread Starter
Lkeyzer's Avatar
These?
Cool I’ll order these prob won’t feel much diff 200vs 190.
Lkeyzer is offline
post #15 of 26 Old 01-01-2019, 05:47 PM
evallarta1's Avatar
A little more info to consider.
190/55 is 2035mm circumference
200/55 is 2064mm circumference
200/60 is 2108mm circumference
As a rider you should very much feel the difference between the 3. Going from a 190 up the scale will take away swingarm angle and decrease trail. The bigger tire helps with contact patch but takes away swingarm angle and trail. This translates to better turn in on entry but causes the bike wide on exit.
Velocity Calibrations
evallarta1 is offline
post #16 of 26 Old 01-01-2019, 05:50 PM
evallarta1's Avatar
Originally Posted by mattinrsm View Post
Dunlop isnít making the 190 slick anymore according to their website. They are selling a 200/55 and a 200/60 which is new and specific they say for liter bikes. I havenít run the 200/60 yet, only the 200/55. The new 200 is about the same diameter as the Pirelli and Michelin 200.
The new Dunlop 200/60 is bigger than the Michelin and the Pirelli, also the Dunlop front is bigger than both.
post #17 of 26 Old 01-01-2019, 09:31 PM
Bottoms-Up's Avatar
Maybe others won't have to, but I had to add a couple of links to fit
the 200 with a +2 rear sprocket.
oh... Pirelli Superbike Slicks for the win!
Bottoms-Up is offline
post #18 of 26 Old 01-01-2019, 10:40 PM
evallarta1's Avatar
Originally Posted by Bottoms-Up View Post
190/55 - 200/60
Be careful with that website. Those numbers arent correct for the size of the tires, not sure where they're getting their numbers from. It's saying ALL manufactures tire is the same size and that's just not true.
200/55-17 circumference
Dunlop - 2064mm
Pirelli - 2060mm
Michelin - 2086mm
Bridgestone - 2057mm
post #19 of 26 Old 01-03-2019, 09:52 AM Thread Starter
Lkeyzer's Avatar
190/55 - 200/60
oh... Pirelli Superbike Slicks for the win! [IMG class=inlineimg]https://www.zx-10r.net/forum/images/smilies/biggrin.gif[/IMG]
What would chain links have to do w anything?
Lkeyzer is offline
post #20 of 26 Old 01-03-2019, 09:54 AM Thread Starter
Lkeyzer's Avatar
190/55 - 200/60
I’m about middle on swingarm- will it push that far? Hope not I have one trackday on this new chain
Lkeyzer is offline
Dunlop GPA Tires toppz462 The ZX-10R 4 05-22-2014 02:17 PM
NEW Dunlop 209 GPA AMA Daytona Sportbike spec tires nikk777 Parts, Gear and Accessories 116 01-04-2011 10:16 AM
FS: Dunlop 208 GPA's & KR106 Racing Slicks mikdivad Parts, Gear and Accessories 2 08-28-2005 10:16 PM
Running Dunlop 208 gpa's on ZX10r realestateguy The ZX-10R 24 10-27-2004 09:45 AM
