tip sensor? - Kawasaki ZX-10R.net
post #1 of 6 Old 03-24-2009, 02:42 PM Thread Starter
tip sensor?
when you turn the sensor over should you hear what sounds like a ball moving around inside the sensor? is this normal, i did a search and didnt find anything quite like this. also is there a way to bypass the the on off switch? i am currently trying to start my motor in my race car but dont have a factory on/off switch i want to run a switch on my dash.
Thanks
Matt
mgm112103 is offline
post #2 of 6 Old 03-24-2009, 02:46 PM
lyodbraun's Avatar
not to sure?? you talking about the tip over sensor?? that is located in the tail section of the bike.
lyodbraun is offline
post #3 of 6 Old 03-24-2009, 03:03 PM Thread Starter
yeah it is the tip sensor and it has an arrow pointing up but when turned over it sounds like a ball is floating inside the sensor
post #4 of 6 Old 03-24-2009, 03:15 PM
LaurenOE's Avatar
Send a message via AIM to LaurenOE
Yes, that sound is normal. It's not an electronic accelerometer, but a mechanical sensor that has moving parts.
LaurenOE is offline
post #5 of 6 Old 03-24-2009, 04:16 PM Thread Starter
if the sensor is bad would this cause the fuel pump to have power but nothing on the coil packs?
post #6 of 6 Old 03-24-2009, 04:52 PM
LaurenOE's Avatar
I'm looking at the 2008 ZX10R Service manual.
The "tip over sensor" is called the "Vehicle Down Sensor" and interestingly the information on it, is contained in the fuel system (DFI) section of the manual.
Under the self diagnosis page - You do know our bikes can output their codes via the instrument gauge, right? - (3-42) - If you get a service code of 31, that signifies that the vehicle down switch is not working. It should have an output voltage of .2 - 4.8v and "If the vehicle-down sensor system has a failure, (the output voltage is out of the usable range, wiring short or open) the ECU shuts off the fuel pump relay, the fuel injectors (primary and secondary) and the ignition system,
So yes. If your sensor is messed up things won't start.
What codes are you getting?
LaurenOE is offline
WTB: Cam Sensor clutch master Wanted: Buy or Trade 1 02-11-2009 09:28 PM
Sensor location 06green The ZX-10R 2 06-30-2008 01:44 AM
TIP OVER sensor? Ninja187 Performance and Tech 8 06-27-2008 12:20 AM
Tip Over Sensor ( Vehicle Down Sensor) Papo-T Performance and Tech 1 06-02-2008 08:12 AM
Cam sensor 1killer1liter Performance and Tech 4 04-06-2006 05:52 PM
