Gen 2: 2006-2007 Time for a valve check & adjustment. Advice needed - Kawasaki ZX-10R.net
post #1 of 13 Old 07-09-2013, 04:32 PM Thread Starter
phasterthanyou's Avatar
Hey Guys,
I'm nearing 15k miles and coming due for valve clearance check and adjustment on my Gen 2. After doing the plugs at 7500 I am not inclined to go much further into the bike without expert assistance. My question is, who would you suggest in the Tampa/Wesley Chapel Florida area to perform the service? Someone/somewhere you have experience with that is reputable, professional, etc? Or, I am willing to pay a technician and/or member to come on over one weekend and assist. I could get everything down to where I did when I did the plugs, which is pretty much just short of the valve cover.
Thanks
phasterthanyou is offline
post #2 of 13 Old 07-09-2013, 04:57 PM
SkyDork's Avatar
Well, checking them is pretty straight forward. It's the adjusting part that's a bit more tedious and involved. I'd offer to help you out with them, but my time is very limited these days. You may try contacting Chad Wolfe, as I've heard nothing but good things about him. He runs an independent shop out of his house. Check him out for contact info on the TSB board.
#WordCrimes
SkyDork is offline
post #3 of 13 Old 07-09-2013, 05:10 PM Thread Starter
I'll probably start there. Like you said, checking clearance is no biggie, its the adjustments, shims, etc.... Sounds scary. I consider myself above average mechanically inclined, and could probably tackle it myself, but would prefer someone that has done it before and knows specific procedures, etc from experience.
Rep sent
Anyone else want to jump in on this topic?
post #4 of 13 Old 07-17-2013, 04:07 PM Thread Starter
Does anyone have Chad Wolfe's phone number?
post #5 of 13 Old 07-17-2013, 04:18 PM
SkyDork's Avatar
I'm not sure it's listed. Did you try contacting him through the local forum? There's a banner right on the home page for him and a sponsor thread. You may have to join the forum to get in contact with him. If I had his number, I'd give it to ya, but I don't.
Check here:
http://tampasportbikes.com/forum/for...Wolfe-Prepared
#WordCrimes
SkyDork is offline
post #6 of 13 Old 07-17-2013, 05:30 PM
thundercoupe9's Avatar
If you're above average mechanic and you can add and subtract simple numbers and have tools it's really not that hard of a job to do, little time consuming, but not hard. If you take your time you can get it done no problem.
thundercoupe9 is offline
post #7 of 13 Old 07-17-2013, 05:44 PM
den33's Avatar
I know this is off topic a little, but at what miles should you change the plugs or airfilter? I have 12k on my bike and still haven't changed these or even the coolant for that matter.. However, she runs cooler and stronger than she ever has..
den33 is offline
post #8 of 13 Old 07-17-2013, 05:51 PM
I can probably make a video on how to do a valve job.
post #9 of 13 Old 07-17-2013, 07:38 PM
SkyDork's Avatar
Air filter and coolant are overdue at that mileage. Filter should be checked at least every 5k IMO. The coolant swapped every 2 years. The valve check and possible adjustment can go to 15k. Same with the plugs.
#WordCrimes
SkyDork is offline
post #10 of 13 Old 07-17-2013, 07:38 PM
SkyDork's Avatar
#WordCrimes
SkyDork is offline
Valve check/adjustment with pics Drain Fade Performance and Tech 83 08-16-2012 09:20 PM
Valve adjustment rafa The ZX-10R 6 06-28-2010 02:56 AM
Valve check/adjustment with pics Drain Fade How To... 6 06-11-2010 06:39 PM
Valve Adjustment walkthisway21 Performance and Tech 23 06-23-2008 01:53 AM
Valve adjustment? CP10R ZX-6R & ZX-6RR Archives 4 02-02-2008 05:10 PM
