tight engine????s - Kawasaki ZX-10R.net
post #1 of 3 Old 08-17-2007, 01:10 AM Thread Starter
tight engine????s
Just reached 15000 mi and did a valve clearance ck, alls good and in spec. Thought I would Degree the cams in since I had it all apart, ( problem #1) this thing is a bitch to rotate over to reach TDC and the only bolt to use is the tiny 8mm on the crank senser, is there a better location to rotate the motor.
supperdaddy is offline
post #2 of 3 Old 08-17-2007, 01:31 AM
SecretAgent's Avatar
Send a message via AIM to SecretAgent
remove the spark plugs.
SecretAgent is offline
post #3 of 3 Old 08-17-2007, 01:43 AM Thread Starter
the plugs are all out, the engine rotates pretty tight and all I have is a little 8mm bolt on the crank trigger side of the crank and worse yet I have to use a longer bolt for my degree wheel which isnt as stout as the factory bolt, any set up Ideas would be great.
Oil filter, how tight is tight enough? YSR50 Performance and Tech 21 08-18-2007 07:52 PM
**NWS**Blue jeans too tight?? Austin10RPowers Adult Content - Photos / Videos - N.W.S. 7 09-02-2006 01:16 PM
Oh my is this thing tight to work on. busaforhire Performance and Tech 13 07-22-2005 11:51 AM
Tight turns 1rocket69 Pictures and Videos 6 05-27-2005 11:15 AM
Ok its not a Bike Video, but.....it tight!! Vonstallin Pictures and Videos 10 12-10-2004 03:10 AM
