Gen 4: 2011-2015 Ticking/knocking - Kawasaki ZX-10R.net
post #1 of 8 Old 07-09-2014, 10:20 PM Thread Starter
Tech5's Avatar
Ticking/knocking
So took it to dealer and told them sounds like tensioner
They had bike 1 week and got it back sounded good .
500 miles later same noise and it's only start up cold. Took it back they replAced it again after another week at dealer because they will not order part unless bike is there .
We'll after 200 miles same knocking / ticking
We'll I took out tensioner, first took off 12mm bolt then spring and pin
Then the two 8mm bolts holding tensioner and gently pry the tensioner out.
Once out I clicked two clicks out installed tensioner and tighten 8mm screws in at same time as it will be a gap and you want tensioner go in straight .
Installed spring first and snugged it in til bottoms out.
Then insert pin with some oil coating it.
Then add bolt and snugged it up with washer on bolt
Cranked it up and bam!!!! Sounds great!!!!
If it comes back I will add manual !!!!
Tech5 is offline
post #2 of 8 Old 07-09-2014, 10:23 PM
Bry
Bry's Avatar
Just curious but was it the OEM tensioner or aftermarket?
Bry is offline
post #3 of 8 Old 07-10-2014, 12:13 PM Thread Starter
Tech5's Avatar
Oem each time
Tech5 is offline
post #4 of 8 Old 07-10-2014, 12:20 PM
zdawg123's Avatar
Get a manual APE cct and cure that ticking. Just be sure to not over tighten
Strictly for the GEN2's Sporting the undertail with pride!
zdawg123 is offline
post #5 of 8 Old 07-10-2014, 01:56 PM Thread Starter
Tech5's Avatar
This is my next step
I will see how long this works
I might also make a manual out of my factory one and make treads and run a bolt thru it
Tech5 is offline
post #6 of 8 Old 07-10-2014, 05:55 PM
Evil10's Avatar
you dont have to take all the way out. pull the spring and pin. use a small bent screw driver to push it in while taping the stater button. I have done a bunch like this. either way it works.
Evil10 is offline
post #7 of 8 Old 07-10-2014, 07:17 PM
The Pace
scout's Avatar
I think you don't wear ear plugs!
scout is offline
post #8 of 8 Old 07-10-2014, 08:09 PM Thread Starter
Tech5's Avatar
True but I wanted to see where it was and I noted just in case I needed to start over
Plus later if it comes back I know th settibg
Tech5 is offline
Gen 2: Knocking noise thebadz32 The ZX-10R 24 03-27-2011 03:07 AM
06 Zx10 knocking!!! TX06'10r Performance and Tech 15 01-12-2009 05:22 PM
Knocking on wood SOUN1 The Out House 17 10-23-2007 12:41 PM
Knocking silversv1k The ZX-10R 3 08-19-2007 12:46 PM
Never knocking on wood again! ZiG 9th The Out House 6 07-14-2006 08:47 AM
