Throttle a little loose - Kawasaki ZX-10R.net
post #1 of 9 Old 05-03-2008, 12:06 PM Thread Starter
DsTroy's Avatar
How do I take the play out of the throttle?
Everyday I'm Hustlin'!
DsTroy is offline
post #2 of 9 Old 05-03-2008, 12:18 PM
Speed Freak
garth285's Avatar
there are two adjustments, one on the pull and one on the play cable..... there is a small lock type of cirle thing that you loosen and then back the main body of the adjuster out.... make sence??? lol.... if its a 04-05 i know theres one usually right near the neck of the frame.....
garth285 is offline
post #3 of 9 Old 05-03-2008, 12:22 PM
YZF
If you can get manual somewhere, it is written very clearly, with pictures.
YZF is offline
post #4 of 9 Old 05-03-2008, 03:20 PM
dbltakeZX10's Avatar
Images: 22
Send a message via AIM to dbltakeZX10 Send a message via Yahoo to dbltakeZX10
1/5 insert will help a lil
dbltakeZX10 is offline
post #5 of 9 Old 05-05-2008, 03:02 AM
Doesn't matter.. Excess throttle play needs to be adjusted out in the manner already posted.
Advanced Kawasaki is offline
post #6 of 9 Old 05-05-2008, 08:05 AM
Images: 22
ok
post #7 of 9 Old 05-05-2008, 08:14 AM
Of course you are faster
Rifleman's Avatar
1/5th will make the throttle "shorter" but it still needs to be adjusted properly.
both the GenI and GenII bikes have an adjustor on the cable up near the tripple tree. Simply loosen the locking ring... back the adjustor out a little, lock the ring back in place.
NOTE: The throttle MUST SPRING RETURN TO IDLE instantly every time... to much tention on the cable can make it slow, sluggish, or even hang in the open position... adjust your cable tention and then test is several times to make sure it snaps back every time, instantly to idle.
This is what you are looking for, obviously they are assembled on your machine.
Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
And another amazing install write up click this
Originally Posted by Rifleman View Post
lol, once you go 1/5th... you NEVER go back
Rifleman is offline
post #8 of 9 Old 05-05-2008, 11:44 AM Thread Starter
DsTroy's Avatar
I would but can't find one anywhere. And I refuse to get the CD rom one on ebay.
DsTroy is offline
post #9 of 9 Old 05-05-2008, 11:46 AM Thread Starter
DsTroy's Avatar
So I don't need to go under the tank?
DsTroy is offline
Ram Air bolts get loose Velociraptor The ZX-10R 6 03-31-2008 12:02 PM
Beware, heated grips + thin throttle tube = stuck throttle Drain Fade The ZX-10R 3 10-14-2007 02:34 PM
Head Set Loose iskysoma01 Performance and Tech 8 01-09-2007 10:26 AM
tailight loose blackgold Performance and Tech 12 07-30-2006 08:54 AM
Loose bolts to look for mad kaw The ZX-10R 7 05-24-2005 05:59 AM
