Throttle issue - Kawasaki ZX-10R.net
post #1 of 5 Old 09-08-2014, 12:03 PM Thread Starter
blackbeast's Avatar
Throttle issue
Ok folks I have a Gen 1 with 1/5 rifleman throttle and last ride I went on when I hit wot it boggs down and only hits 10k rpm. If I'm at 3/4 throttle it'll wind up to redline. Surely one of you gurus cam help me out... thanks in advance.
John
blackbeast is offline
post #2 of 5 Old 09-08-2014, 01:31 PM Thread Starter
blackbeast's Avatar
No it is not hitting the Rev limiter at wot.
post #3 of 5 Old 09-09-2014, 05:04 AM
Driaannel's Avatar
1. Side stand switch
2. fuel pump
3. plugs
4. kinked fuel line
5. collapsing ram air tubes
6. shitty fuel (was the problem in my case)
these are a few things i remembered to check when i had the problem. 1 and 2 are the most common problems
Driaannel is offline
post #4 of 5 Old 09-09-2014, 08:15 AM Thread Starter
blackbeast's Avatar
Thanks. I checked all those and I am still having same problem. Any other suggestions? Anyone. ....
post #5 of 5 Old 09-09-2014, 08:38 AM
Driaannel's Avatar
might be easier if you tell us what you have tried.
Just remembered. it can also be the exhaust valve servo.
Rear tire slippage - tire issue? Suspension issue? Rider issue? silversixspeed Suspension and Tire Tech 41 10-25-2014 01:00 AM
Gen 4: Throttle surging issue ssbandit158 The ZX-10R 7 05-31-2013 05:08 AM
Throttle Issue WTF??? ghost_sniper_777 Performance and Tech 7 02-18-2011 09:06 PM
Lingering throttle issue just got worse. Jax 10 Performance and Tech 30 05-07-2008 03:52 AM
Beware, heated grips + thin throttle tube = stuck throttle Drain Fade The ZX-10R 3 10-14-2007 02:34 PM
