Throttle Housing Screws - Kawasaki ZX-10R.net
post #1 of 20 Old 01-05-2009, 06:46 PM Thread Starter
Postwhore with an 04
bcm0018's Avatar
Angry Throttle Housing Screws
I know its been complained about before but it came back and got me again so figured I'd complain about it again. I hate the screws in the throttle housing. They are really tight and the bolt heads are weak. Took some work to get them out. Only other time they were out was when I did the 1/5th throttle. :headshake
This one came out with vice grips
This one was the one I got creative with
bcm0018 is offline
post #2 of 20 Old 01-05-2009, 07:11 PM
Hated.Or.LoveIt's Avatar
Yeah that one got me too...
Hated.Or.LoveIt is offline
post #3 of 20 Old 01-05-2009, 07:20 PM Thread Starter
bcm0018's Avatar
Yeah after the 1/5th throttle I figured they were never coming off again. Knowing myself I should have replaced them right then and there :headshake Oh well a lil more business for the sponsors.
bcm0018 is offline
post #4 of 20 Old 01-05-2009, 07:28 PM
I stripped the head on one of them and one came off without a hitch. Those were some of the most annoyying bolts I've worked on for sure.
killersrt is offline
post #5 of 20 Old 01-05-2009, 07:35 PM Thread Starter
bcm0018's Avatar
Yeah the top one was accessible so I just clamped on it with some vice grips but the bottom bolt was recessed so I drilled the head off and then pulled the housing apart. Then it was easy to get out but I tried other things first and failed miserably.
bcm0018 is offline
post #6 of 20 Old 01-05-2009, 08:54 PM
PatrickG's Avatar
Images: 15
Those are some cheap ass bolts/screws. After destroying mine I went to the hardware store and bought some allen headed bolts, painted the heads of them black. I will never have that problem again.
PatrickG is offline
post #7 of 20 Old 01-05-2009, 09:51 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
Never had any problem with mine when I did the 1/5 throttle
Lucky10R is offline
post #8 of 20 Old 01-05-2009, 09:54 PM
can we ride yet!?!?!?
coolgjc's Avatar
is that locktite on the threads?
coolgjc is offline
post #9 of 20 Old 01-05-2009, 10:06 PM Thread Starter
bcm0018's Avatar
Yeah but its the weak stuff. I had a hell of a time with them when I did the 1/5th. Had to use an impact socket to get them out.
bcm0018 is offline
post #10 of 20 Old 01-05-2009, 11:09 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
If anybody else has issues like this, you can take a dremmel and a cut off wheel and carefully cut a slot in the head and use a large sturdy flat blade screwdriver.
To get these screws out without destroying them, the correct head screwdriver is imparitive, use the largest one you can get to fit and make sure it does not have a sharp point on the tip. Extreme downward pressure while turning is also super important!
9R to 10R is offline
04 Fairing Screws javeci01 The ZX-10R 5 07-05-2008 01:34 PM
Spare screws tas9195 ZX-6R & ZX-6RR Archives 8 06-16-2008 10:53 PM
Screws and Boltz ninjazx10r The ZX-10R 5 02-18-2005 08:29 AM
Help with fairing screws? morrisjl2 Performance and Tech 11 12-23-2004 08:44 AM
bolts and screws falling out silvrsled The ZX-10R 27 08-08-2004 10:11 PM
