Gen 3: 2008-2010 Throttle body sensors - Kawasaki ZX-10R.net
post #1 of 4 Old 05-22-2012, 10:47 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
Hey guys..
Just replaceing the secondary fly motor on my gen 3 and now just puttin it back together when i realized somethin......The two sensors on the brake side of the throttle body,i didnt mark them to which one goes where...Any hints cause they are both just spring loaded but wired for one or the other flys..They have different part # inked on them but look and act the same and im not seeing any # that match online
I tried an exploded view of the repair manual and a cpl other sites with micro fiche but none show the right side of the tb...
Suggestions..
craig_sez is offline
post #2 of 4 Old 05-23-2012, 03:11 AM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
sensors
post #3 of 4 Old 05-23-2012, 08:17 AM
gazx10's Avatar
pull up the srvice manual in this forum, main throttle sensor, sub throttle sensor, shows what u are looking for. wire color coding is given and shown for each sensor, they are different. if not marked precisely, main tb tps must be reinstalled with dc voltmeter to correct values. input 5 volts dc, output, which controls fueling and timing .65 volts dc at 1100 rpm idle progresses as opened to 3.95 volts at wot. just went thru this, if off a little, your tune is way off. good luck.
gazx10 is offline
post #4 of 4 Old 05-23-2012, 12:12 PM Thread Starter
Newfie Bullet
craig_sez's Avatar
Images: 34
Jesus..thank god I got a 1200 mile throttle body commin anyway..I was told 1200mi and no code issue for 175 usd plus shipping..JUST IN CASE...
Tks for your efforts..
Gen 3: Throttle body actuator craig_sez Performance and Tech 20 06-15-2012 02:23 PM
07 throttle body tps help gazx10 Performance and Tech 10 04-22-2012 09:53 AM
Throttle body plate rppjr Wanted: Buy or Trade 0 04-01-2012 07:13 PM
Throttle body mod??? 1bad10r Performance and Tech 25 01-27-2007 06:49 PM
need throttle body help hongthaomurphy Performance and Tech 12 07-12-2006 10:50 PM
